Author Topic: WTB S2 RR hub carrier  (Read 573 times)
Offline SwiftDB4
« on: Friday,March 24, 2017, 01:28:22 PM »
Looking for S2 RH rear hub carrier. OK with bearing bore wear as I'm planning on having it sleeved. Must have OK bolt threads.
Dave Miller
davemarylee@msn.com
« Last Edit: Friday,March 24, 2017, 01:30:29 PM by SwiftDB4 »
Re: WTB S2 RR hub carrier
« Reply #1 on: Friday,March 24, 2017, 09:08:26 PM »
Dunno if you are missing one or have a damged one.  If the latter, it is pretty easy to helicoil the threads.  It's actually a good idea as well as the repaired threads are much stronger.
« Reply #2 on: Monday,March 27, 2017, 10:24:57 AM »
I have a spare pair. There is a bit of wear/damage to the bore section, hard to see from the photo. I can send it to you for inspection, if you want it $50, other wise send it back.
The first picture shows the S2 hubs on top with TCS hubs below. It was hard for me to tell the difference between the two until they were side by side.
Fallbrook, Ca
Offline SwiftDB4
« Reply #3 on: Monday,March 27, 2017, 10:11:11 PM »
Thanks Joji for your offer, but I bought a hub carrier earlier today.
