Author Topic: Lotus Europa Wilwood Rear Disc Brake Upgrade Kit  (Read 17694 times)
Re: Lotus Europa Wilwood Rear Disc Brake Upgrade Kit
« Reply #90 on: Tuesday,March 23, 2021, 08:19:05 PM »
I like them a lot, no issues.  Moves the suspension design out of the 40s.
The rotors are EBC brake offerings.  They have an (expensive) option for slotting and dimpling.  I wouldn't buy them again myself.  Look cool though.
Offline literarymadness
« Reply #91 on: Tuesday,March 23, 2021, 08:57:10 PM »
The dimples are good for wet weather and the slots reduce the friction in the brake pads and shave down glaze from overheated brake pads. Slots by themselves are also good for wet weather and give water a place to go. Either one does not necessarily improve braking, but they do improve the brake environment which aids braking in unfavorable conditions.
« Last Edit: Tuesday,March 23, 2021, 09:00:32 PM by literarymadness »
Offline Chuck Nukem
« Reply #92 on: Tuesday,March 23, 2021, 09:28:18 PM »
Progress today! I am getting the bracket design finalized. I need to tweak a few things with tooling and set up to give a better finish on the back side. The pictures speak for themselves though! 7.8 lbs factory vs 3.13 lbs of the aluminum 4 piston
The floating rotor design I have right now with a separate aluminum hat that mounts to the standard hub saves almost a lb.
With my integral floating hub I am expecting to save a further 3 lbs over the old set up.
I am also scheming about an aluminum upright that uses ball joints like JB's
« Last Edit: Tuesday,March 23, 2021, 09:33:58 PM by Chuck Nukem »
« Reply #93 on: Wednesday,March 24, 2021, 03:31:34 AM »
Nice work!
« Reply #94 on: Wednesday,March 24, 2021, 06:40:16 AM »
Really nice, Chuck!
Offline gideon
« Reply #95 on: Wednesday,March 24, 2021, 07:46:56 AM »
That looks great. I like the way you built a bracket for a radial mount caliper in a single piece of aluminum.
Offline Chuck Nukem
« Reply #96 on: Wednesday,March 24, 2021, 07:54:54 AM »
Thanks guys! Here are some pics of the set up. I am going to make special soft jaws to hold the part for OP 3. I had it just resting on parallels with maybe .050 clearance between the vise and the tool.... I like to live dangerously.... The unsupported area gave me the rougher finish on that face.
Its one more step to do it this way but I feel the end result is better! Many radial arrangements use a sub bracket that converts axial mount to radial.
I used a form tap to make the threads so they should be plenty strong. I am going to tweak the tool path to add a chamfer before I tap so the little bump doesn't swell past the face when the tap goes in.
« Last Edit: Wednesday,March 24, 2021, 07:56:25 AM by Chuck Nukem »
« Reply #97 on: Wednesday,March 24, 2021, 10:02:08 AM »
Very impressive work all 'round, Chuck. I am amazed at how much weight could be saved over the original assembly.
Offline Dave Richardson
« Reply #98 on: Tuesday,April 20, 2021, 02:15:46 PM »
Really nice work.  The weight savings are impressive.
