Author Topic: Lotus Europa Wilwood Rear Disc Brake Upgrade Kit  (Read 17697 times)
Offline Dave Richardson
Re: Lotus Europa Wilwood Rear Disc Brake Upgrade Kit
« Reply #75 on: Saturday,March 20, 2021, 10:30:46 AM »
I would be interested in purchasing a Wilwood based rear disk brake conversion kit.  Are they still available?
Offline Chuck Nukem
« Reply #76 on: Saturday,March 20, 2021, 11:28:30 AM »
Serge and I are both working independently on this project. What series car do you have?
« Reply #77 on: Saturday,March 20, 2021, 01:40:42 PM »
1974 TCS Type 74. Thanks.
« Last Edit: Saturday,March 20, 2021, 01:42:40 PM by Dave Richardson »
Offline Chuck Nukem
« Reply #78 on: Saturday,March 20, 2021, 09:59:03 PM »
Serge will undoubtedly be finished before I am. He has a great set up and we actually happened upon the same integral parking brake wilwood calipers for the rear.
I am setting out to make my rear kit work with the TCS wheels and retain the parking brake. I am making aluminum hats and using OEM front rotors with the centers milled out to take fixed or floating hardware from AP. The shorter hat I pictured is a prototype for the front.
The trouble is the rotor can only be pushed back so far before it hits the trailing arm. The special p brake calipers leading actuator hits the inside of the wheel. I am going to machine a new low-profile arm with a ball socket to replace it. Wheel spacers would help matters but I am trying to avoid them if possible. If you don't need a p brake that would greatly simplify things.
« Reply #79 on: Monday,March 22, 2021, 08:36:32 AM »
Looking good, Chuck.
Have you considered a vented rotor option for the front, or is that an unnecessary complication?
« Reply #80 on: Monday,March 22, 2021, 08:46:28 AM »
That looks great, Chuck!!!  :beerchug:
Offline Chuck Nukem
« Reply #81 on: Monday,March 22, 2021, 09:48:00 AM »
Thanks!!
I have. Wilwood makes the Powerlite radial in two sizes so you could run ventilated if you go with the larger size
https://www.wilwood.com/Calipers/CaliperList?subname=Powerlite
Ideally I would tweak the location of the ventilated rotor by adjusting the offset of the aluminum hat so the same bracket could accommodate both offsets.
Long term I am designing a new aluminum hub which accepts the rotor via AP floating (or fixed) hardware instead of the traditional 4 bolts. This saves the weight of the bolts and the associated material needed. I have been scratching my head about this because the normal aluminum hubs are plentiful and cheap, so this is my logical evolution to that set up. Another feature I want to integrate is a bearing spacer tube (similar to the rear bearings) because I have read of improvements in stability. I hope to have some real parts to show everyone soon :)
Nietzsche argued it is the tool which insists on cutting rather than the user's genuine proclivity to act...I believe his analogy was the knife of a murder is the ever suggestive force that demands use from its owner... It's not that I need this hub... but rather that my machine lusts for chips :)
Offline literarymadness
« Reply #82 on: Monday,March 22, 2021, 01:31:03 PM »
Anybody who can quote from Nietzsche is my kind of friend.  :beerchug: You might want to post your disc brake progress also on the Rear Disc Brakes post from a month ago. It have over 2100 hits; so there is a lot of interest in the subject and it might be easier for people to find than in the classifieds. I'm sure a lot  more people would want to follow your progress. But what you are doing looks great.
Offline gideon
« Reply #83 on: Monday,March 22, 2021, 01:55:31 PM »
Chuck, that looks interesting.  I applaud the desire to save weight and reduce the number of parts.  FWIW, I was thinking of buying the uprated front hub and stub axle kit from Canley Classics, which I hope will solve the stability issues with the OE hub and stub axle.
https://www.canleyclassics.com/?product=uprated-front-hub-and-stub-axle-kit
I'd be interested to hear if anybody else has this kit?
Offline Chuck Nukem
« Reply #84 on: Monday,March 22, 2021, 02:01:11 PM »
Thanks Literary :)
Thanks! JB has it and I've seen positive praise come from him and others.
« Reply #85 on: Monday,March 22, 2021, 09:24:25 PM »
Yup, got it and it's very strong. Two large, sealed, tapered rollers with perfect machining mean no play whatsoever.
Offline gideon
« Reply #86 on: Tuesday,March 23, 2021, 08:03:32 AM »
Wow. Thanks for the pictures.
Offline lotusfanatic
« Reply #87 on: Tuesday,March 23, 2021, 11:51:14 AM »
Thanks JB!
Very shiny!  8)
« Reply #88 on: Tuesday,March 23, 2021, 03:52:30 PM »
I have a couple of spare hubs coming and I'm going to see if I can do a vented rotor conversion.  I found some Toyota rotors that might the ok-ish.  Busy as heck though so don't hold your breath waiting for news.
Offline Blitzen
« Reply #89 on: Tuesday,March 23, 2021, 07:34:57 PM »
JB, are those their trunnionless uprights? How do you like them?  Also what rotors are those?
