Author Topic: Alum water pipes  (Read 2790 times)
Offline Runningwild
Alum water pipes
« on: Wednesday,January 25, 2017, 04:33:31 PM »
I'm planning on using alum tubing for my water pipes.  My question is what type of alum tubing would be the best.  Any thoughts?
Offline Serge
    • Sleurs Motorsport
Re: Alum water pipes
« Reply #1 on: Wednesday,January 25, 2017, 10:36:27 PM »
I used T66 with a wall thickness of 1.5mm and used silicone bends to join straight pieces of aluminium together. Easier to make and a lot less stress on the aluminium tubing.
Serge
Offline Runningwild
« Reply #2 on: Thursday,January 26, 2017, 04:24:57 AM »
Thanks Serge. That's what I was planning in back but didn't know what type of tubing. How are you doing the front bends. Are you leaving the tubes straight.  I'm going with a cable shift system and don't want the tubes to interfere with the shifting.
« Reply #3 on: Thursday,January 26, 2017, 05:32:55 AM »
I used  Aluminum 2024-T3 1.25" x .049".  It could have been thinner wall. Beading it was hard.
« Reply #4 on: Thursday,January 26, 2017, 07:06:46 AM »
Serge has an S1 which has straight tubes through the chassis "tunnel".  So he beaded the tube ends and use silicon hose for the bends in the engine compartment.
Offline HealeyBN7
« Reply #5 on: Thursday,January 26, 2017, 02:54:27 PM »
I did something similar. I ran straight anodized aluminum pipes low in the chassis.  It required punching new holes in the front bulkhead so the pipes would both stay low and clear my cable shifter.  I used an epoxy bead on the ends instead of welding and messing up the anodize.  So far it has been working.
« Reply #6 on: Thursday,January 26, 2017, 04:31:42 PM »
Thanks for that idea Dean. I was just at the metal shop yesterday checking pipe choices and availability.
« Reply #7 on: Thursday,January 26, 2017, 04:55:23 PM »
I saw a Youtube video of someone using vise grips with a muffler clamp to bead tube. That's how I did mine.
https://www.youtube.com/watch?v=2oGqB2HQXVQ
« Reply #8 on: Thursday,January 26, 2017, 05:51:53 PM »
You can also just fit four rivets.
« Reply #9 on: Thursday,January 26, 2017, 11:29:29 PM »
:) good post, thanks for that video.
I'm amazed how inventive some folks are to get around problems, that's so simple but effective.
Offline Runningwild
« Reply #10 on: Friday,January 27, 2017, 05:38:41 PM »
I really like your idea of putting a second hole at the bottom to run the tubes straight and at the bottom of the frame. Eastwood sells the beveled hole punches to match the original holes. I was thinking of having the alum tubes Swain coated like we do on our race cars headers. Shouldn't that cut down on the heat build up in the tunnel?
Offline Serge
    • Sleurs Motorsport
« Reply #11 on: Saturday,January 28, 2017, 05:03:28 AM »
Yes, a ceramic type coating like on exhaust manifolds is a perfect solution for minimising the heat in the tunnel.
I used a tube-beader for the beads and like John said, mine is an S1,so the tubes are straight.
Offline FranV8
« Reply #12 on: Saturday,January 28, 2017, 05:26:00 AM »
I've had to replace one of mine (lower) on a TCS.  I've used plain 32mm OD steel seamed tubing, painted and managed to slide it all the way through the car with the grill removed.  The rear riser (vertical section with two bends) that would have originally been part of the same tube, had rotted so I've made up a new section and am using a short section of silicone hose as a joiner.  I've not swaged the ends (the originals weren't) - but have upgraded from the original wire clips to Mikalor clamps.
