Author Topic: TCS brake boosters  (Read 1093 times)
Offline Europa73
TCS brake boosters
« on: Monday,January 23, 2017, 05:02:33 PM »
Hi all,
My TCS brake boosters are working great but looking rough.
Has anyone taken them off to give them a lick of paint?
is this an easy process?
Cheers,
Re: TCS brake boosters
« Reply #1 on: Monday,January 23, 2017, 05:32:06 PM »
It isn't difficult to take them off but keep in mind you'll be opening your brake system up and you'll have to bleed it again. I've never bled a stock brake system but I have read that it isn't a fun job and maybe not something you'd want to do if you didn't have to. Have you considered masking off the surrounding area and painting them insitu?
Offline Europa73
« Reply #2 on: Monday,January 23, 2017, 05:43:28 PM »
cheers!
it is a nest of brake lines there
Offline tedtaylor
    • TaylorMadeClassicCars
« Reply #3 on: Tuesday,January 24, 2017, 05:28:59 PM »
here's a link to an article/blog I wrote working on my boosters and bleeding the system (full brake job).  No big deal, so go ahead and remove, restore/paint, and reinstall with a system bleed.
http://lotuspals.ning.com/forum/topics/rebuild-your-servo-boosters-don-t-toss-them-away-or-bypass-them
Happy to see another owner keeping and maintaining their brake boosters as original equipment. :)
TED
'13 Evora S
Offline Europa73
« Reply #4 on: Tuesday,January 24, 2017, 05:53:50 PM »
Cheers!
Offline E Paul
« Reply #5 on: Wednesday,January 25, 2017, 11:08:12 AM »
Speed Bleeders are your friend!
Paul
4525R
Offline Europa73
« Reply #6 on: Thursday,January 26, 2017, 10:05:52 AM »
Thanks all,
In addition - if there is anyone else out there looking to service / rebuild these bad boys, I have the following links
a great step by step .pdf
http://volvo1800pictures.com/document/Girling%20Hydralic%20Servo%20unit%20MK%202A%20and%202B/Girling%20Hydralic%20Servo%20unit%20MK%202A%20and%202B.pdf
Rebuild kit - including diaphragm
http://www.jlspares.com/sealkits1.htm
I will let you know how it goes
« Reply #7 on: Thursday,January 26, 2017, 11:44:45 AM »
Check the bores of the hydraulic cylinders carefully!  Any corrosion or noticeable wear means you need to replace or sleeve the cylinders.
Offline Europa73
« Reply #8 on: Thursday,January 26, 2017, 12:24:15 PM »
Will do.
Thanks,
