Author Topic: Heater piping removal Question?  (Read 587 times)
« on: Sunday,January 15, 2017, 03:52:12 PM »
I thought since the frame is bare, except for these 2 sections of pipe, I might as well replace them. If I don't, I know one or the other, or both will spring a leak in the frame tunnel shortly after (if ever) I get car reassembled.
At the frame 'Y'. I can see where they are tack welded. It appears they are tack welded inside the tunnel, at the 90 degree bend where they come up thru the frame?
How to cut them loose?
Thanks in advance
Re: Heater piping removal Question?
« Reply #1 on: Sunday,January 15, 2017, 04:12:36 PM »
Mine were tack welded where they poke through the chassis near the heater box and where they exit at the rear.  Nothing in-between.
« Reply #2 on: Monday,January 16, 2017, 04:40:10 AM »
Same with mine, tack welded at the ends. I'm leaving mine intact as they seem to be on good condition. (of course now that I said that I might regret not changing them out)
« Reply #3 on: Monday,January 16, 2017, 05:36:21 AM »
Mine tested fine until they had hot, pressurized coolant in them.  If you have the engine and transaxle out, just change them.
« Last Edit: Monday,January 16, 2017, 04:17:27 PM by jbcollier »
« Reply #4 on: Monday,January 16, 2017, 07:31:07 AM »
Thanks for the info.
I thought it may be prudent to replace.
Offline Runningwild
« Reply #5 on: Monday,January 16, 2017, 01:56:33 PM »
Who stocks the pipes other than Banks
« Reply #6 on: Monday,January 16, 2017, 02:11:44 PM »
I've not actually looked. I thought about just getting some tubing and having it bent.
