Author Topic: advice on dashboard light  (Read 1037 times)
Offline Europa73
« on: Sunday,January 15, 2017, 02:50:20 PM »
Hi all,
The prior owner of my car put in the new dash and pad - unfortunately he did not cut an opening for the dash light that goes above the heater control.
At the moment I just have a bright light coming from inside the dash :-)
Please see the attached pic.
Any advice (or pics) on what the light hole should look like and be located?
e.g. is it a hole or a slit as with the arm rest.
Many thanks,
Re: advice on dashboard light
« Reply #1 on: Sunday,January 15, 2017, 02:59:11 PM »
There's supposed to be a "cavity" above the heater controls where the light goes. Usually, the crash pads don't come with them and the guy who installs it has to make it. I'll try to get a picture of mine but I'm in the middle of things.
Offline Europa73
« Reply #2 on: Sunday,January 15, 2017, 03:01:54 PM »
Many thanks,
I have the recess in there - can get my fingers in there - look forward to seeing the pic.
Cheers,
« Reply #3 on: Sunday,January 15, 2017, 06:31:56 PM »
Here's the picture of my light:
« Reply #4 on: Monday,January 16, 2017, 05:44:37 AM »
Why not just pull the bulb and not worry about it?  It's not as though it is actually doing anything useful.
Offline FranV8
« Reply #5 on: Monday,January 16, 2017, 09:39:43 AM »
Yes, but didn't Colin say simplify and add lightness? :)
Offline Europa73
« Reply #6 on: Monday,January 16, 2017, 10:25:51 AM »
Thanks all much appreciated - taking out the bulb would be the simple option.
Cheers,
« Reply #7 on: Monday,January 16, 2017, 03:52:20 PM »
I attached a photo of the original foam crashpad showing the location and method to attach the dash bulb.  I also attached a photo of a Banks fiberglass crashpad modified to accommodate the dash bulb.  I used foam in a can from Home Depot to fill the center of the crashpad.  I then cut a hole in the foam for the bulb and a slit in foam, fiberglass and vinyl to let the light through to the dash.
Offline Europa73
« Reply #8 on: Monday,January 16, 2017, 05:30:39 PM »
The photos are great.
Many thanks,
