Author Topic: two wires without a connection  (Read 983 times)
Offline Europa73
« on: Friday,December 23, 2016, 04:13:02 PM »
Hi all,
Could you take a look at the attached pic?
I have found 2 wires not connected to anything - they go into the harness  - cant find them on the wiring diagram.
I found them hanging on the drivers side to the left of the steering column
any help would be great
Re: two wires without a connection
« Reply #1 on: Friday,December 23, 2016, 06:40:48 PM »
This is fun!
The long answer:
You may already know there are two versions of the wiring diagram depending on your chassis number. For wiring diagrams, I like to go here (http://lotus-europa.com/manuals/) and scroll down towards the bottom there are color coded wiring diagrams. So you pick your diagram based on your chassis number (or just the last four digits and letter) check out your diagram. I checked both since I didn't know what chassis number you had but couldn't find your white/green wire. There were several purple wires, but none that seemed to be yours. I also looked up your wires in the Lucas wire color code (http://www.jcna.com/library/tech/tech0014.html) and your white/green is supposed to be for fuel pump #2 or change over switch and your purple wire is supposed to be for accessories fused direct from battery. That didn't seem helpful.
Then I gave up and looked on my car (3635R) and found your wires. They weren't connected to anything. I would have thought they were connected to something like a key or door buzzer or seat belt switch since I disconnected all that crap but I didn't find them on the wiring diagram.
The short answer:
I'm ignorant and apathetic. I don't know and I don't care. My car runs. There is nothing that I want to work that doesn't (except for my courtesy light and I don't think I did a good job of connecting the bullet connector the last time I had the carpet board off).
I don't want you to suggest that you ignore a wire...  But I will!   :)
« Last Edit: Friday,December 23, 2016, 07:09:49 PM by BDA »
Offline Europa73
« Reply #2 on: Friday,December 23, 2016, 07:57:31 PM »
Many thanks -
Greatly appreciate the effort -
Cheers,
« Reply #3 on: Friday,December 23, 2016, 10:39:35 PM »
Think this has come up before and, if I recall correctly, they are for the key/seatbelt warning buzzer circuit.
Offline Europa73
« Reply #4 on: Saturday,December 24, 2016, 06:02:44 AM »
Cheers,
With regards to the wires - I think I will just safely tuck them away -
Thanks,
« Reply #5 on: Tuesday,December 27, 2016, 10:16:45 AM »
If the car is a late model federal TC it is the wires to the key buzzer.
