Author Topic: Banks brass door hinge  (Read 2205 times)
Offline Europa73
« on: Sunday,December 18, 2016, 11:09:46 AM »
I need to replace my door hinges.
Question - has anyone tried the brass door hinges from Banks?
See the attached for a pic
Cheers,
Re: Banks brass door hinge
« Reply #1 on: Sunday,December 18, 2016, 12:24:23 PM »
I have them. I can't compare the effort required to adjust the doors between the original Lotus system and Richard's brass hinges but I suspect, in spite of my less than spectacular door adjustment (one is pretty close and the other is not but will latch securely at least! - fixing that will be my next project!), I think they are a big improvement, if for no other reason than that you can take the door off and only worry about adjusting the height - none of the other adjustments will change, but they seem like they'd be easier than the original system.
Obviously brass will not rust like the original hinges. r.d. has a set of stainless steel hinges in the same style as the original system if you want to go that route.
Offline jjbunn
« Reply #2 on: Sunday,December 18, 2016, 12:43:40 PM »
I have them, too. Still quite fiddly to adjust, but they are works of art!
Offline Europa73
« Reply #3 on: Sunday,December 18, 2016, 01:51:40 PM »
Thanks all
« Reply #4 on: Monday,December 19, 2016, 12:43:39 AM »
I have them on mine as well.  They are a treat to work with and are a big improvement over the stock set-up.
« Reply #5 on: Monday,December 19, 2016, 11:15:52 AM »
(+1) x 7
