Author Topic: TCS steering ignition lock  (Read 1900 times)
« on: Wednesday,October 05, 2016, 02:31:26 AM »
One of next many tasks is to sort out the ignition steering lock on the TCS. The current lock is a WASO lock that I think was used on Triumphs. Frustratingly I have the compete lock but no key  :'(   I have had no luck so far in finding a key or work out a way to re-profile the lock, or just buy a barrel & key and the only option seems to be to buy a new lock and £150+, so before I go and do that has anyone got any ideas?
Re: TCS steering ignition lock
« Reply #1 on: Wednesday,October 05, 2016, 03:50:47 AM »
Richard at Banks has found a way.
Cheaper than £150 I believe.
I have that path to follow soon.
Alex in Norfolk.
Offline blasterdad
« Reply #2 on: Wednesday,October 05, 2016, 04:14:33 AM »
Here ya go... http://www.triple-c.com/Lotus_Replacement_Car_Keys.cfm
Lotus key cut to code on your lock, $12.95 US.
They have lots of other cool stuff too... ;)
« Reply #3 on: Wednesday,October 05, 2016, 06:28:06 AM »
We just take the ignition switch/column lock unit off and bring it to our local locksmith.  They have always been able to cut new keys.  The unit is held on by "tamper-proof" bolts.  We use a small cut-off saw to cut a slot in the smooth head and turn them out.  New ones are available from Triumph part suppliers.
« Reply #4 on: Friday,October 07, 2016, 12:14:34 PM »
Hmm, thanks a locksmith is probably the best next bet.
« Reply #5 on: Friday,October 07, 2016, 01:52:44 PM »
I removed the electrical cap off the back of the ignition switch to find a paper label with a hand written three digit code that was the key code.  I did this with the lock still in place.  Even in extreme Lotus position I could not read the label.  So I used a digital camera.
There is sure to be a local locksmith who can cut the key from the code, if not see Blasterdad's reply.
P.S., I photoshoped (changed) the code in this pic.
« Reply #6 on: Monday,October 10, 2016, 01:16:22 AM »
Good idea to check for a code. didn't think of that, but there is nothing obvious. The switch on mine was already parted from the lock itself when I got it, but will see if there are any clues
« Reply #7 on: Monday,October 10, 2016, 06:34:09 AM »
Lotus records have the key codes.
« Reply #8 on: Monday,October 10, 2016, 07:41:27 AM »
Thanks,
Thats' an even better ideas. I'll drop Andy at Lotus an email.
« Reply #9 on: Monday,October 31, 2016, 03:50:12 AM »
Progress., i have the key code for the lock. Next challenge what do I do with the code!!  May have success, keeping my fingers crossed!
Found a company Morlands. Morlands.demon.co.uk. that can produce the key £12.95 plus postage. A bargain if it works. I'll update with the results.
« Reply #10 on: Monday,November 07, 2016, 01:13:06 AM »
Result it's fits! wheyey! :trophy:
Best £20 spent so far! A bit of jiggling as the lock not been used for 30 years, worked a treat. The key by the look is OEM or similar as it's been plated after being cut.
« Reply #11 on: Monday,November 07, 2016, 05:11:22 AM »
Excellent! That has to feel good!
« Reply #12 on: Thursday,November 10, 2016, 01:30:32 PM »
 :beerchug:
