Author Topic: ignition timing  (Read 2333 times)
Offline phil
ignition timing
« on: Sunday,September 18, 2016, 12:53:24 PM »
Hello all,
Im trying to find a section in the Europa workshop manual detailing engine timing using a strobe light, Ive found that it should be 12Deg BTDC, and No.1 cylinder is nearest front of car? Only other info is for the Renault engine.
I need some details on the timing marks etc if possible?
Regards   Phil
Offline TCS4605R
Re: ignition timing
« Reply #1 on: Sunday,September 18, 2016, 01:13:15 PM »
Phil,
I use 30 deg. before top dead center at 3,000 RPM and yes the cylinder nearest the front of the car is No. 1 - my timing is for a 40DCOE Weber head on a Twin Cam with L cams.
74TCS - 4605R
Re: ignition timing
« Reply #2 on: Monday,September 19, 2016, 06:06:41 AM »
TC timing is found in the "engine tuning" section of the TC workshop manual.
http://www.lotus-europa.com/manuals/tcwork/e/index.htm#3
Offline Pete
Re: ignition timing
« Reply #3 on: Friday,April 16, 2021, 11:11:22 PM »
Hi.
I’ve been looking into timing. I’ve read the manual about how to do it etc. But can’t find what advance I should be setting it too. Does it very for every engine. I see Tom said he sets it to 30deg but that’s at 3k rpm. Yet the manual says to set it at 2.5k rpm. But doesn’t say what deg.
Thanks again
Pete
Europa S2 1970 great car
Me complete novice mechanic..
Offline literarymadness
Re: ignition timing
« Reply #4 on: Friday,April 16, 2021, 11:47:56 PM »
If you click on the link JB posted go to E3 (#12) where you saw the 2500 rpms and click on (see Technical Data) and then click on "Ignition System", the Timing Degrees are there.  It says 14 degrees maximum advance (that is on top of the 12 degrees static).  That is a total of 26 degrees Euro-spec and 21 degrees Fed-spec. But those numbers are conservative, especially the Fed-spec. If you are running 93 Octane (US) or 98 RON (Euro) and your motor has hotter cams, you can advance higher.
Offline Dilkris
Re: ignition timing
« Reply #5 on: Saturday,April 17, 2021, 05:38:27 AM »
If all else fails and if the car is mobile - do it be trial and error and "feel" - take it down the road and see how she behaves - she will tell you when she is happy.  :) :)
Re: ignition timing
« Reply #6 on: Saturday,April 17, 2021, 07:36:40 PM »
Setting timing by ear is fine for light road use.  Drive flat out and you could well hole a piston.  Always, always check your total advance with a timing light.
Offline Dilkris
Re: ignition timing
« Reply #7 on: Saturday,April 17, 2021, 07:40:49 PM »
What did we do before the advent of timing lights and color tune kits John....???  :confused:
Re: ignition timing
« Reply #8 on: Saturday,April 17, 2021, 08:46:07 PM »
Timing lights go back a long way.  You had to mark the degrees on the pulley yourself.  I used to use simple arithmetic to calculate and mark the pulleys.  It’s not that hard.  They had distributor machines as well.
People used to time air-cooled VWs by ear too.  Man, they ran great... until the first long hill.
Offline Pete
Re: ignition timing
« Reply #9 on: Tuesday,April 20, 2021, 07:44:31 AM »
The timing strobe light I found in my uncles garage was next to useless at trying to light it up. I’ve picked up some tipex to mark the points on the wheel and casing. Think I will have to do it in the dead of night too. Lol
Re: ignition timing
« Reply #10 on: Tuesday,April 20, 2021, 08:16:20 AM »
Modern timing lights are available, usually with xenon bulbs so they can be used most any time.
