Author Topic: Converting a Zenith/Stromberg Head to a Twin 40 DCOE Head  (Read 21648 times)
Re: Converting a Zenith/Stromberg Head to a Twin 40 DCOE Head
« Reply #120 on: Thursday,February 16, 2023, 09:50:18 AM »
Well, it was Chunky. So cost would be my first thought. Does the head have enough meat in the right places for bolting a manifold, if Lotus had tried that approach?
« Reply #122 on: Monday,May 01, 2023, 07:06:52 AM »
Just finished rebuilding the engine with the Zenith Stomberg head converted to Weber inlet manifold.
The engineering shop forgot to drill and tap the hole for the brass tube servo vacuum take-off.
The thread is 1/8" NPT (National Pipe Taper). My local tool shop had the tap, I took the alternator pulley wheel off, stuffed kitchen roll tissue in the inlet manifold, made sure the inlet valve was shut, drilled an 8.5mm hole, and the tap went straight in with a bit of WD40.
The brass vacuum take off union fitted perfectly. I thought that was mission impossible. Result.
