Author Topic: Ok, now I'm paranoid...  (Read 570 times)
« on: Sunday,September 04, 2016, 06:13:01 AM »
After installing the doors, you bet I‘m paranoid!
I’m surely going to end up in Europa perdition as I fit large door speakers to my S1.  One completely unexpected benefit is that, apparently, you can hear sound through them: music, books on tape, FM radio (AM? You’ve got to be kidding), what-have-you; quite amazing really.  However, that’s not why I fit speakers to the doors.  I did it because it makes fitting and adjusting the doors actually a breeze.  Access to the door hinge gibbons and adjustment nuts is great and small adjustments are easily made: a highly recommended mod.
Also, just yet another big thumbs up for the Banks brass hinges: best outrageous amount of money I ever spent.  Vertical adjustments are easily done, lateral adjustments not too far behind and door removal/installation very straight forward.
The paranoid part?  That someone might actually lean on, or pull themselves up by the doors!  So I fit a pair of these:
https://jbcollier.smugmug.com/Lotus-Europa/i-xZ9fMZd/A
John
Re: Ok, now I'm paranoid...
« Reply #1 on: Sunday,September 04, 2016, 08:17:12 AM »
Hi John,
just wait until some bright spark decides to try and lift themselves out by pulling on the windscreen pillar.......   now that does get shouted at !
« Reply #2 on: Sunday,September 04, 2016, 08:59:46 AM »
That should have been on every new Europa!
