Author Topic: WTB: various S2 bits  (Read 997 times)
Offline bozman
  • It's a Europa with an "e" at the end.
« on: Thursday,August 25, 2016, 11:20:58 AM »
Looking for the following (original equipment):
Throwing this out there, in case anyone has these items laying around collecting dust.  Thanks!
Wanted:
- rear lower links
- radiator fan motor
- front wire mesh panel
- original steel rims (do not need center caps)
- 155 R13 tires (4)
- S2 badge (that is on the rear wing)
- black carpet set
« Last Edit: Monday,October 03, 2016, 12:08:31 PM by bozman »
Offline grnicholson
Re: WTB: various S2 bits
« Reply #1 on: Friday,September 02, 2016, 05:02:25 AM »
Hello
I've got a radiator fan including bracket, in working order.  You can have it for free just pay the postage or arrange collection yourself.
cheers
Richard in sunny spain (Alicante)
« Reply #2 on: Friday,September 02, 2016, 06:25:16 AM »
Early rad fans are adapted from a Renault puller application (pulls air through the rad) and just reverse wired to make the fan a blower.  Unfortunately the blades of the fan are curved to suit the puller application and work with significantly reduced efficiency when reversed wired in a Europa.  This caused overheating issues in warm climates.  All that to say, get a rad fan actually designed to be a blower.
