Author Topic: WTD: Heater Fan for Twin Cam  (Read 3002 times)
Offline s2europa
« on: Wednesday,August 17, 2016, 08:51:58 AM »
I am looking for a working heater fan (the one that is mounted in the front luggage compartment) for a twin cam Europa. Let me know if you have one for sale. Thanks, Dan
Re: WTD: Heater Fan for Twin Cam
« Reply #1 on: Wednesday,August 17, 2016, 12:04:27 PM »
I have bought computer 12v fans from Maplin and will install 1 on each of the side vent holes, and one behind the heater matrix, so you can individually switch the 3 to get better heating etc.
IMHO the original fan only worked if you put nothing in the compartment, and had a perfect seal between the opening cover and the body.
« Reply #2 on: Wednesday,August 17, 2016, 10:44:04 PM »
Unless you're aiming for an original look to the front compartment, I can now confirm that the motorcycle blower I fitted a few months ago really does work well. I mentioned it briefly in this thread just after I'd bought it;
http://www.lotuseuropa.org/LotusForum/index.php?topic=1538.msg13948#msg13948
It's now fitted and is so far improved from the OEM version it's like a different car. I think the reason is the way the air is channelled forwards into the compartment, plus of course the blades are a more efficient design and probably shift more air from that alone.
You need to be creative in making up mounts of course, and this installation does need tidying up (another winter job  ;)  ) but otherwise it's a fairly straightforward mod.
Offline E Paul
« Reply #3 on: Friday,August 19, 2016, 12:14:42 PM »
Mine died a number of years ago and NAPA had a Delco unit that was a direct bolt-in.
Paul
Offline s2europa
« Reply #4 on: Friday,August 19, 2016, 01:07:05 PM »
Paul, do you happen to have the part number for the fan? Thanks.
« Reply #5 on: Friday,August 19, 2016, 01:23:18 PM »
Offline E Paul
« Reply #6 on: Monday,August 22, 2016, 08:35:59 AM »
Sorry, I don't. It was a really long time ago.
Paul
Offline bozman
  • It's a Europa with an "e" at the end.
« Reply #7 on: Thursday,September 01, 2016, 05:40:06 AM »
Dan,
There is a guy on ebay selling a Twin Cam Radiator Fan.  He also has a heater blower mower for sale, although it is not posted.  You may way to contact him:
Mike Lemke: racersedge817@msn.com
(I was interested in the radiator fan, so I had him send me a pic and I saw the heater blower in the pic.)
Offline s2europa
« Reply #8 on: Thursday,September 01, 2016, 08:18:06 AM »
Thanks for the tip. I have emailed him.
Dan
