I came across the Ford Festiva master cylinder as a promising candidate for a replacement S2 master cylinder and decided to see how I could make it work for the S2. The main requirement for my conversion was not to make the conversion permanent but to allow reverting back to the stock S2 master cylinder if I later changed my mind. This is what I came up with.
The master cylinder is from a 1988 thru 1993 Ford Festiva (Pic 1):
-non stepped, 0.75” tandem bore
-dual ports on right hand side, M10 x 1.0 metric fittings
-integral plastic reservoir w/low fluid level sensor
-mounting lugs oriented horizontally (east/west)
The most obvious issue was adapting the horizontal orientation of the mounting lug holes of the Festiva MC to the stock vertical mounting system. My solution was to design an intermediate mounting flange welded to the stock MC extension box (Pic 2 & 3).
There is also an issue with moderate interference between the Festiva MC flange and the original mounting bolts of the extension box (Pic 4 ). There are two options to overcome this problem. The first is to ground out a couple of notches on top and bottom edge of the MC to clear the bolts (Pic 5). I chose this option. In retrospect, I should have cut out the bolts and drill and tap the stock holes for a 5/16” NF stud. This second option would have made for a cleaner installation and still allow using the stock MC if wanted to go back.
The second issue is the pushrod system used by the Festiva, It's a straight rod fitting about an inch into the center of the primary piston (Pic 6&7). The Europa does not have a pedal stop to prevent the pushrod from pulling out of the primary piston. The solution used is identical to the Courier MC conversion, a washer between the extension box and the frame (Pic
New brake lines will have to be run from the Festiva master cylinder to the two three way junctions on the front bulkhead. Metric fittings, M10 x 1.0 on the master cylinder and 3/8” x 24 for the junctions.
The swap out and road test of the Festiva MC on 65/2501 will be performed in a couple of months. I just replaced the unknown installed front pads for EBC Green Stuff pads as reference pads for testing the stock versus the Festiva MC. I need to get some experience of stock MC with the EBC pads. My gut feeling is that the Festiva MC will perform identically to the Courier MC. I'll post a follow up evaluation after my road test.
My final thoughts. With Spitfire MCs still readily available, the Festiva conversion will probably not be the first choice in alternate master cylinder conversion for the Europa . Most of the effort with the Festiva MC was as a fabrication exercise, seeing if it would be possible to overcome the issues needed to adapt it to the S2. A more detailed explanation with additional photos is available in my Dropbox account at:
https://www.dropbox.com/s/1ttog0n2pp21r10/Adapting%20a%20Ford%20Festiva%20master%20cylinder%20to%20a%20S2%20-V2.odt?dl=0Joji Tokumoto
Fallbrook, Ca
