Author Topic: 807-13  (Read 1002 times)
Offline BERNIEHUMBER
807-13
« on: Sunday,July 24, 2016, 01:57:43 PM »
HI:Here is a shot of a 807-13. I know some go in with out a modified mount where others need a plate.Which do I have?The car is 2 hrs away so I wanted to go prepared.
Thanks
Re: 807-13
« Reply #1 on: Sunday,July 24, 2016, 02:02:26 PM »
I think that should go straight in.
Re: 807-13
« Reply #2 on: Sunday,July 24, 2016, 02:04:02 PM »
Re: 807-13
« Reply #3 on: Sunday,July 24, 2016, 02:27:11 PM »
HI:Thanks.I was looking at that shot of the 821-04 block and every second time I looked I found a problem,you know watch something long enough and you start to doubt yourself!!!
I had a bit of a problem finding the 42 mm intake valves(FI engine) but I would rather deal with a 42 mm than some of the 807-13's with the 40mm.I had to do a bit of porting to make the twin 40 Webers feel at home on the head but this isn't a overnight project.
Thanks again
Bernie
Re: 807-13
« Reply #4 on: Sunday,July 24, 2016, 03:58:54 PM »
Easy on the porting.  You want a nice gentle taper from the carbs through to the valve.  Especially do not lower the "floor" of the port.  This is a common mistake as it "visually" improves access to the valve.  It actually directs flow across the valve which significantly lowers the air flow.  Sorry, just a hobby horse of mine.
Re: 807-13
« Reply #5 on: Sunday,July 24, 2016, 05:03:27 PM »
HI:Used a flow bench (inclined manometer in thermo lab where I teach) to do a before and after.Easy to remove, hard to replace.If you mess with the actual seat dimensions, way more harm done than positive effect.
Take care
