Well Mike, I'd be tempted as well. If I had space to store it (the toyboxes are currently full
) I'd buy that simply because it's incredibly cheap. $500 for a front end plus front bonnet ? A bargain even if you don't do your own glass fibre work.
Although replacing an entire front end is a big job, you also have the option of cutting repair sections from it, i.e. the front corners to repair the usual low speed accident damage ?
