Author Topic: Chassis repair  (Read 1348 times)
Offline Runningwild
Chassis repair
« on: Thursday,June 23, 2016, 04:11:47 AM »
I've got the chassis media blasted and now I have to fix the cracks. What gauge steel did lotus use?  Have cracks in the front T and one by the rear shock mount.
Offline Gearbox
    • The Lola Registry
Re: Chassis repair
« Reply #1 on: Thursday,June 23, 2016, 08:04:43 AM »
On mine I found that it was 18 ga and 16 ga, or 0.047" to 0.06".  Since you are doing this, you should consider doing the 26R mods, relatively simple and makes the chassis much more rigid.  I think I have 3D CAD drawings of the parts and can send you 2D PDF's to trace and cut out the parts if you like.  They are all flat pieces, so should be easy to make.  Let me know, Thanks Allan
Note:  Just realized that this was the Europa Forum and not LotusElan.net opps, never mind.
« Last Edit: Thursday,June 23, 2016, 01:22:54 PM by Gearbox »
Re: Chassis repair
« Reply #2 on: Thursday,June 23, 2016, 01:01:08 PM »
I can confirm that the several points that I checked with a sheet metal gauge front and rear are 16 gauge steel. The fit was very tight due to corrosion.
Re: Chassis repair
« Reply #3 on: Sunday,June 26, 2016, 03:34:39 PM »
Common places for cracks to develop.  Photos?
Offline Gearbox
    • The Lola Registry
Re: Chassis repair
« Reply #4 on: Sunday,June 26, 2016, 07:18:53 PM »
On the two Europas I had restored, both TCS, the main problem areas was at the "Y" and the trailing arm mount areas.
Offline Runningwild
Re: Chassis repair
« Reply #5 on: Tuesday,June 28, 2016, 04:00:42 AM »
Small crack in the front T.  Same on the other side
Re: Chassis repair
« Reply #6 on: Tuesday,June 28, 2016, 10:10:51 AM »
That crack looks more than a little rusty.  Have a good poke about with a sharp ice pick.
