Author Topic: Fuel pump connection  (Read 833 times)
« on: Tuesday,May 31, 2016, 01:40:56 PM »
I am installing my fuel lines on my TCS. It gas  an ac Delco mechanical pump. With glass bowl. I am missing one of the fuel line connectors. So I am after one. A threaded male connector and the pipe, I Don't think it's  1/4 npt. Anyone got any ideas?
Offline EuropatcSPECIAL
Re: Fuel pump connection
« Reply #1 on: Tuesday,May 31, 2016, 02:00:51 PM »
I could be wrong but I think you have to buy the full thing, is this the feed to the carbs? I know Banks have them   I may have the wrong end of the stick here.
« Reply #2 on: Tuesday,May 31, 2016, 02:15:44 PM »
I got loads of those connectors from QED in Quorn.
They are like gas compression connectors. You just fit them on copper pipe with the olive that comes with the fitting.
Alex in Norfolk.
« Reply #3 on: Tuesday,May 31, 2016, 02:40:02 PM »
Ta. I'll check out QED forgot about them when I was hunting
« Reply #4 on: Tuesday,May 31, 2016, 09:55:01 PM »
If it is a compression fitting, then a hardware store, plumbing or industrial supply.
