Author Topic: Fuel Sender Unit removal tool  (Read 716 times)
Offline EuropatcSPECIAL
« on: Monday,May 30, 2016, 02:51:38 PM »
Good day every one. I need to replace the sender unit on the left hand side tank of my Europa Special. It lists a tool for the job in the workshop manual but I've searcher for one including  second hand but no luck. Has anyone any pointers or what have they used instead.
Thanks in anticipation
Stuart
Re: Fuel Sender Unit removal tool
« Reply #1 on: Monday,May 30, 2016, 04:30:55 PM »
If it's not rusted,  I usually tap them off with a blunt punch and a hammer.  You can't just hit on one tang you have to work all three sequentially as best as possible.
« Reply #2 on: Tuesday,May 31, 2016, 03:40:40 AM »
cheers JB
« Reply #3 on: Tuesday,May 31, 2016, 06:58:49 AM »
Too much force with a hammer and chisel and you risk breaking or bending a tang. A simple tool to make is to cut slots in a round piece of plastic drain pipe coupler 120 degrees apart.
« Reply #4 on: Tuesday,May 31, 2016, 01:58:05 PM »
Good suggestion, not sure what the diameter of our drain pipes are on this side of the pond. thanks for the photograph Grumblebuns, all the best Stuart
