Author Topic: Adjusting rear camber with Banks Twin Link  (Read 926 times)
Offline invjbo
« on: Monday,April 11, 2016, 02:07:48 AM »
Hi,
I suspect my car has to much negative camber on the rear, and would like to try and correct this. If i look in the original documentation it says it should be between 0-2 degrees negative. As my car is fitted with an Banks Twin link rear suspension kit and I dont have any specifications for the kit. Does anyone have any specs for this or should i try to adjust it to 0-2 degrees as original?
Best regards
John
Lotus Europa S2 -71
VW Golf Gti -16
Bayliner 2455 -01
BMW S1000XR -16
Husqvarna Fe 450 -16
Re: Adjusting rear camber with Banks Twin Link
« Reply #1 on: Monday,April 11, 2016, 05:39:36 AM »
 You should use the camber recommendations in the manual.
« Reply #2 on: Monday,April 11, 2016, 06:16:28 AM »
Yup, set it to factory specs BUT make sure you also check the rear toe-in which may change with any adjustment you make.
