Author Topic: A little progress  (Read 3140 times)
Offline blasterdad
A little progress
« on: Wednesday,March 30, 2016, 01:49:38 PM »
Snuck in some time to work on the Lotus last night & behold a familiar sight!
After a little time with the wire wheels...
Just need to make a new bracket for the bottom. I even consulted the Magic 8 Ball if I could fix it & it told me "signs point to yes".  ;D
Pretty sure this was part ( if not all ) of the reason the clutch would not work, ( felt it crunch apart when I pushed it down ).  ;)
Re: A little progress
« Reply #1 on: Wednesday,March 30, 2016, 06:59:03 PM »
That looks great, blaster! So, if you get the pedals working, does that mean you can drive it? This is Lotus driving season!
Offline blasterdad
« Reply #2 on: Thursday,March 31, 2016, 05:13:56 AM »
Yes, all the way to the garage stall next to it for further work.  :FUNNY:
Offline TCS4605R
« Reply #3 on: Thursday,March 31, 2016, 10:13:51 AM »
Blasterdad,
Look in the 'Yahoo Lotuseuropa' site in the Files section, look for 'Tandem Master Brake Cylinders' - there are PDF drawings of the pedal assembly base plate and drawings of all of the other bits and pieces to fabricate a new pedal assembly.
Offline rascott
« Reply #4 on: Thursday,March 31, 2016, 11:52:59 AM »
sounds like you have what's left of the base for a pattern. if it comes off the floor in one piece.
my rusty lump showed no signs of ever having grease zerks- that's a good idea.
Offline blasterdad
« Reply #5 on: Saturday,April 02, 2016, 07:19:29 AM »
Blasterdad,
@Tom, Thank you for the lead, I'm going to see what's left of the base today. Good to have another option on file!  ;)
@Rascott, I remember the pics of the "clump", was feeling fortunate by comparison when I removed mine. You did an outstanding job fabricating new ones by the way!  :)
« Last Edit: Saturday,April 02, 2016, 07:21:34 AM by blasterdad »
« Reply #6 on: Saturday,April 02, 2016, 08:51:31 AM »
Awesome! As far as my pedals are concerned the 8 ball said "better luck next time"
Offline TCS4605R
« Reply #7 on: Saturday,April 02, 2016, 11:37:16 AM »
The reason I built a new clutch/brake pedal assembly is because my clutch pedal broke off at its base leaving me in traffic with no clutch.  Luckily, it was not the brake pedal.  I also wanted an assembly that would work with tandem brake cylinders.  The stock Lotus assembly does not fair well with age.  I think there are some pictures of the completed assembly on the 'lotuseuropa yahoo' website.  Both the brake and clutch pedals rotate on needle bearings on my assembly.
Offline blasterdad
« Reply #8 on: Sunday,April 03, 2016, 06:56:31 PM »
Got the base out tonight, one bolt came out, (miracle), two broke, (yaaay), one met Mr. Grinder...
Amazing how thin the metal was,  :o  pretty important part to make out of sheet metal, no wonder it rotted away.
« Reply #9 on: Sunday,April 03, 2016, 07:17:11 PM »
Congratulations, blaster!
Maybe the S2 pedal base is made of thinner stuff but the one in my TC wasn't so thin...
In any event, it's a great time to either make or buy a beefier one!  :)
Offline TCS4605R
« Reply #10 on: Tuesday,April 05, 2016, 02:55:09 PM »
If your pedal assembly base was rusted that bad, you might want to check the outer seat belt anchor plates on each side of the fiberglass body.  They are held in place by bolts accessed inside the car - at least on the Twin Cam - best with the seats out.  My pedal assembly base was not rusted very much, but the two outer seat belt anchors were pretty well rusted thru.  Failure of the anchors and you are an unrestrained projectile in an accident.
Offline blasterdad
« Reply #11 on: Tuesday,April 05, 2016, 05:22:31 PM »
We seem to have had opposite problems, just the pedal base & one seat track rusted on mine. I was lucky enough to find someone local who had 3 of them! So far those seem to be my only rust issues,(knock wood). We will see when the body comes off.  ;)
Offline blasterdad
« Reply #12 on: Saturday,May 14, 2016, 04:31:08 PM »
Started to disassemble the body & wiring a couple of nights ago.
A PO had made click splice spaghetti of the front wiring harness in an attempt at fixing a problem that didn't exist.
After removing the aforementioned mess I was left with a perfectly functioning  front harness in very good condition.
Unhooked the coil & tested the rest of the car  for the first time.
Everything worked except the turn signals, which was quickly resolved with the discovery of one of the wires to the flasher had fallen off.
Was also blessed with both windows opening & closing flawlessly for the first time in 30 years!
All this is now GONE!
« Reply #13 on: Saturday,May 14, 2016, 05:32:44 PM »
Great news, blasterdad! That's got to feel good!
Offline blasterdad
« Reply #14 on: Thursday,September 01, 2016, 02:12:39 AM »
Finally got around to finishing the pedal base Tuesday night, (tried to post all this yesterday morning & my computer crashed the SECOND I tried to click on post!  :headbanger:)
Pic #1. Plate laid out & pilot holes drilled...
Pic #2. 1/4 inch holes drilled...
Pic #3. Cut out radius with a cutoff wheel...
Pic #4. Cleaned up seats with a rat tail in a drill...
Pic #5. 'Viola...
Pic #6. Just right...
Weld & paint are on the to do list for today! Pics to follow... :welder:
