Hello everyone,
so took my Special to his first drive this year. It fired up OK and I started to drive it around. It was nice and I had much fun. I remembered why I liked this car so much! Everything was fine ... until ... I got a peculiar odor to my nose, checked the rear view mirror ... was that track behind me, from my car? checked front, all OK, checked rear view again, all OK. Fine.
Until my view ahead got a little foggy. there was some smoke/vapor coming from the front!
I stopped and took a look into the front compartment. Everything was wet, where the spare tire was! I had lost cooling fluid.
After the first shock I checked the hoses, they where OK. Then I noticed a small opening in the side of the radiator. A plug had blown out.
I looked for this plug, but couldn't find it. The I noticed some small device dangling from some wires hanging there (nothing out of the ordinary with Europas, I thought), but it fitted nicely into the opening! That must be the thermometer! (I am not that deep into every technical aspect of my car, you. will notice)
OK, opening plugged, but still without cooling water. Lucky me, there where some houses not far away. From there I got some water and they even borrowed me the watering can, so I got back to my garage.
I like some excitement, when driving, but not this sort.
So, questions. How could this happening? Is there nothing securing the thermometer in place? I guess/hope the water pump is OK, but how to check?
Best regards,
Uwe
