Author Topic: Rvi to Rvc conversion Spiyda  (Read 1300 times)
Offline ezuskin
« on: Monday,March 21, 2016, 07:00:30 PM »
Hi group,
I have been looking at this company's products. There is a board that is semi plug n play but also an external device that does not require opening tach. The buffer around $60us and board around $66us.
Does anyone have any experience with their products?
Eddie Zuskin
2068R
Eddie
Europa TC
1972 2068R
Re: Rvi to Rvc conversion Spiyda
« Reply #1 on: Monday,March 21, 2016, 11:04:11 PM »
Hi Eddie,
If it's this place
https://www.spiyda.com/magento/index.php/smiths-rvi-rvc-conversion-board.html
then, I've seen the same company and it looks a really neat way to convert a tach. The first time I saw it was on the Lotuselan.net forums because as you'd expect, Elans have the same tach problems with electronic ignitions.
http://www.lotuselan.net/forums/elan-mods-f31/rvi-tachometer-conversion-t26919.html
and
http://www.lotuselan.net/forums/lotus-electrical-f38/please-help-understand-ignition-wiring-tacho-t29435.html
It's a far neater solution than transplanting modern innards and I've been considering trying one on a spare tach because I do like the idea of being able to calibrate this one from your PC.   The external driver module is a new one to me, I've not seen that before.
« Reply #2 on: Tuesday,March 22, 2016, 06:02:16 AM »
I modified my Elan tach with the internal kit. Greatly recommended.
