Author Topic: Removing the steering column ?????  (Read 1435 times)
Offline Runningwild
« on: Thursday,March 10, 2016, 11:30:35 AM »
My last Step before separating the body from the chassis. Is there an easy way to detach the steering column from the rack?  I don't see how to get a wrench on the bolts connecting the lower column to the rack.  I see the bolts but how do you get them off?  Thanks. Tom
Re: Removing the steering column ?????
« Reply #1 on: Thursday,March 10, 2016, 11:58:52 AM »
You have to undo the 4 x 7/16th nuts holding the steering rack in place, then move the rack away from the body, to get to the 1/2" nuts and bolts on the UJ at the bottom of the column.
I did that last weekend.
The hard part, and it can be very difficult, is stopping the very long bolts from moving round while you undo the 7/16" self locking nuts.
If the bolts do rotate, use a hacksaw blade, cut a slot in the exposed part of the bolt, put a small screwdriver into the slot to stop it rotating, and slowly undo the 7/16th nut. I had to do that on 2/4 nuts/bolts.
Alex in Norfolk.
Offline Runningwild
« Reply #2 on: Thursday,March 10, 2016, 12:03:49 PM »
Alex. Thanks. Makes sence now.  Tom
« Reply #3 on: Thursday,March 10, 2016, 12:09:29 PM »
The heads of some of the long bolts are in a black hole in the middle of the front crossmember of the chassis.
To access those heads, you need the fingers of a ballerina, 6" long,  and a flexible 7/16 spanner (wrench).
HTF they did it on the production line I don't know. Mind you they breed them a bit strange up here in Norfolk. 6 fingers etc !!!
Alex in Norfolk.
« Reply #4 on: Thursday,March 10, 2016, 08:20:58 PM »
When you put them back, get some 1/2" wide mild steel strip, say 16 gauge, about 3 inches long, and drill a 1/4" hole in the middle. Pop your bolt through that, then braze or tack weld in place, a bit of paint for protection, then fit inside the crossmember.
No more bother unscrewing and you wont need steel fingers.
Offline ezuskin
« Reply #5 on: Monday,March 21, 2016, 07:08:55 PM »
This might be old news but I had mechanic weld 2" or 3" x 1/2" strips to bolt head for at least 3 of 4 bolts for rack. Had  to trim one of them  shorter. Goal was that they got stuck on pieces of inside of chassis so I could get nuts started. The 2 times I remove rack I just cut off the nuts to save my sanity.
Eddie Zuskin
2068R
Eddie
Europa TC
1972 2068R
