I haven't owned a vehicle with a carburetor and more than one cylinder for several decades.... my relearning/ learning curve is steep and I'm stuck...
My starter died a slow death last month. I replaced it and now the car turns over fine but won't start
. I do not think the new starter or dead starter are related to my current problem. The car started running rough and stalled at idle immediately (<5 minutes!) before I parked it and ordered the new starter. It had also unexpectedly cut out/ died once at freeway speeds and then just as unexpectedly restarted (push/bump start) on the off ramp. Otherwise the car was running great just 5 minutes before parking and ordering the new starter.
Mine is a 73 TCS that matches this wiring diagram-
http://www.lotus-europa.com/manuals/misc/electrical/tcsearly.gif It has a Mallory Voltmaster Mark II ignition coil (aka cold start coil) with external ballast resistor. It has a Lucas distributor (stock?).
Observations:
-All plugs look a bit carbon fouled (I hope to get new plugs tomorrow*). I think a result of repeated unsuccessful attempts at starting and not cause of not starting?
-Timing light suggests that all plugs wires are getting some voltage (enough to trigger the timing light to flash).
-Visual inspection of distributor rotor and cap looked ok. (How do I get to the points?).
-White wire on ballast resistor is getting hot enough to melt the insulation (wire that runs to tach).
-Tach seems to only work when starter is engaged???
-New gear-reduction starter required combining the two wires connected to the solenoid (one spade terminal on the new starter, two on the old). I did this per info on the knowledge base and think it is correct, but....
-I don't think it is a fuel problem. This is based on the sudden onset and fact that a dose of quick start into the intake plenum has no effect.
Any ideas, suggestions, or disparaging remarks on how to proceed?
How do I test the coil and resistor? Any suggestions for an ignition coil and/or resistor? On my current resistor the wire to the tach (see right wire in pic below) is on a round button shaped thing. Is this a second resistor and could it cause the hot connection?
*I'm having a hard time finding NGK BPR7ES plugs. Any other suggestions?
Sincerely,
Europa Knob
