Author Topic: Renault distributor advance curves in Alpine A110 engines  (Read 1969 times)
« on: Wednesday,February 24, 2016, 12:52:55 PM »
Engine specs:
https://jbcollier.smugmug.com/Lotus-Europa/i-J2b7j9F/A
Distributor specs:
https://jbcollier.smugmug.com/Lotus-Europa/i-6GMDwHc/A
Advance curves:
https://jbcollier.smugmug.com/Lotus-Europa/i-JjCS4c3/A
Close up of the 1565 & 1600 advance curve:
https://jbcollier.smugmug.com/Lotus-Europa/i-K2gfSVX/A
Sorry, it’s a copy of a copy.  Bottom scale most likely reads 450/1000/1500/2000/2500/2600
Re: Renault distributor advance curves in Alpine A110 engines
« Reply #1 on: Wednesday,February 24, 2016, 01:00:49 PM »
Please note these are distributor advance curves.  The distributor turns once for every two engine revolutions so you double the spec if you are using crankshaft rpm and degrees advanced.
