Author Topic: Steering wheel removal  (Read 4873 times)
Re: Steering wheel removal
« Reply #15 on: Saturday,January 30, 2016, 04:26:58 AM »
I doubt you will get it off pulling by hand. It is a tapered fit like a tie rod. They are designed to not just pull off.
Offline blasterdad
« Reply #16 on: Saturday,January 30, 2016, 05:54:18 AM »
I've pulled many by hand, I start by pulling at 12 'o clock, then 6, back & forth. Then 3 & 9, then 2 & 8, then 4 & 10.
Usually twice around it will pop off, if not, have someone TAP on the shaft while you do it like JB said...
It will come off.  >:D
« Reply #17 on: Saturday,January 30, 2016, 08:00:38 AM »
When you finally do get it off, you should wire brush the splines on both the shaft and the steering wheel and maybe even put some antiseize, oil, or grease on them when you reassemble it. The antiseize is way overkill but why leave any opportunity open to go through this again? I doubt this will be the last time you take the steering wheel off.
Offline elcaminokid
« Reply #18 on: Sunday,January 31, 2016, 08:23:04 AM »
Success!  :trophy:
I got the steeringwheel off today. I used a bearing puller on the inside of the steering wheel hub. Had to tighten it quite a bit and then, suddenly, a loud 'pop' and then I could take it off by hand.
Would it be ok to use coppergrease on the spline (not on the thread) when reassembling?
« Reply #19 on: Sunday,January 31, 2016, 08:49:47 AM »
I would think a very small smear of Copperslip would stop any corrosion of the metal surfaces. Clean up the splines, put a small amount of Copperslip on the splines,put the wheel back on, clean any surplus that comes out from the hole, and take the wheel back off. Make sure that the two surfaces have a thin covering and clean any excess before re-assembly. Make sure the nut is tight. Put it on full lock when you tighten to stop the wheel going round but don't overtighten it.
« Reply #20 on: Sunday,January 31, 2016, 04:30:34 PM »
Generally not a good idea to lube a taper fit.  It allows the parts to fit together tighter with less force and possibly distort.
« Reply #21 on: Sunday,January 31, 2016, 04:55:26 PM »
I was going to suggest that it is a straight spline, but I think you're right about a taper - I had never thought about it before.
I figured some lube would keep the interface between the two pieces from freezing and make it slippery and easier to get off the next time. What would you suggest, John?
« Last Edit: Sunday,January 31, 2016, 05:00:45 PM by BDA »
Offline elcaminokid
« Reply #22 on: Sunday,March 27, 2016, 03:51:51 AM »
Hi all, got my steering wheel back all nice and re-upholstered:
Very pleased with the result! They did a very good job :-)
« Reply #23 on: Sunday,March 27, 2016, 07:37:15 AM »
How much did that cost to re-upholster?
I have one which has been dinner for several rodents !
Alex in Norfolk.
« Reply #24 on: Sunday,March 27, 2016, 09:22:23 AM »
Sorry BDA, asleep at the wheel again.  Some do have a straight spline but then they have a clip or shoulder onto which the wheel tightens -- Jags with adjustable columns are one example.  Most though have a slight taper.  Clean and dry are the norm for any taper fit.  If you feel you must use a lube then reduce your tightening torque.  Lubing a taper with one part being steel and the other aluminium is especially problematic as the aluminium "forms" to the taper.  Too much torque means the aluminium "de-forms" and you could end up with the nut tightened down to the shoulder and the taper still not secure.  This is where lubrication causes problems as it greatly lowers the torque required to deform the aluminium taper.
Further, aluminium on steel tapers behave differently than steel on steel tapers.  Once tightened, over time the aluminium taper settles and forms to the steel taper.  This may cause the nut to appear to loosen.  If you keep tightening the nut, the aluminium taper will continue to settle and work its way along the steel taper until the alloy taper is ruined.  The forces involved are generally too small with a steering wheel but, in other applications such as bicycle crank arms, you have to be very careful.
« Reply #25 on: Sunday,March 27, 2016, 11:22:17 AM »
Thanks for the great information (as usual), jb! My steering wheel doesn't give me any problems and I don't use any lube - maybe partially because I've had it off several times since I got the car on the road! And also because I never tighten it that hard - snug and then a little more.
Kid, your wheel looks great!!
Offline elcaminokid
« Reply #26 on: Monday,March 28, 2016, 08:30:51 AM »
Alex in Norfolk.
Was €120, including return shipping from Germany. Turnaround time was just over a week.
