The hinges on 4259R were particularly badly rusted with no chance of pulling them down.
I started drilling the 1/2" bar half way up the door, and at the bottom above the nuts, with a 2.5mm drill, up to a 10mm drill, then there was a big enough hole to break the bar away.
Then I drilled the two nuts up to 12mm, and they fell apart in half.
You have to be careful not to snap the drill bits. I got through plenty.
If the hole is too far to one side, turn the bar 90 degrees so the large bit is away from you, and drill into the flat surface on the large bit left.
When the nuts are snapped in half, the bottom of the door becomes loose around the rusted bar.
Get Mole grips on the upper part which is usually not rusted, and just loosen it back and forth until it drops down. The top of the door is now free.
Then lift the top out carefully, and then lift the door off the remainder of the bottom bar and nuts.
When the door is off, you can easily get to the stub of the 1/2" bar in the bottom sill, and either cut it with a grinder flush, and then carefully knock it in to the sill, or if too badly stuck, centre punch the stub and drill until enough is drilled away to knock down.
You need a plentiful supply of drill bits 2.5mm to 10mm, about 30-40 mins per door, and a steady hand.
The hardest bit is getting the 2.5mm drill started on the round bar (centre punch a dent) then the bar is quite soft and easily drilled.
