Author Topic: What does your Europa look like *today* ?  (Read 124240 times)
Offline Hf_martin
Re: What does your Europa look like *today* ?
« Reply #375 on: Friday,May 20, 2016, 08:51:40 PM »
That looks great.  What carbs are those and what ignition system are you running?
Thanks,
I'm running Mikuni carbs from a Suzuki gsxr and a megajolt ignition system.
/Martin
« Reply #376 on: Thursday,May 26, 2016, 08:19:11 AM »
Good luck on the test run. Your car looks beautiful. Post up a couple more pics when you get a chance. Cheers.
Offline Chuck Nukem
« Reply #377 on: Sunday,June 05, 2016, 08:25:33 AM »
Mine are reunited at the new house, and they look neglected! Getting ready to make them a little lotus hutch on the side of the house so I can work in the garage...
« Reply #378 on: Sunday,June 05, 2016, 08:30:20 AM »
They look pretty sad there covered with dust! At least they can keep each other company!
« Reply #379 on: Monday,July 11, 2016, 08:41:04 AM »
At the Eaglewood Festival of Speed.
I suppose it was a bit like the Goodwood festival in that they both have cars and people.  :))
Note that good looking sticker on the right side of my rear window.
« Last Edit: Monday,July 11, 2016, 08:43:04 AM by 3929R »
« Reply #380 on: Monday,July 11, 2016, 08:49:19 AM »
Well done sir, good to see the message is getting about !  (mine is in exactly the same place as well)
The car's pretty sharp as well, you've obviously been round it with the polish.
« Reply #381 on: Monday,July 11, 2016, 08:50:54 AM »
Very nice car and VERY nice sticker!
 :lotus:
Offline Serge
    • Sleurs Motorsport
« Reply #382 on: Tuesday,July 12, 2016, 02:46:41 PM »
I'm working on two S1 fuel tanks. The first one needs a little bit more welding done and then some leak testing. I haven't been AC TIG welding for long, so I'm just a beginner, but practice makes perfect.
Blind theaded bobbins for mounting and a drain plug.
« Reply #383 on: Tuesday,July 12, 2016, 03:19:11 PM »
That looks great for a beginner!!!
Offline Serge
    • Sleurs Motorsport
« Reply #384 on: Saturday,July 16, 2016, 01:13:07 PM »
Managed to weld up the right hand side fuel tank. Had to touch up 3 little spots after leak-testing, but everything is fine now. Welded in two bosses on top, one for a VDO-style tube fuel sender (no float on a pivot) and roll-over vent. Left hand tank will come out even better, hadn't welded anything this big in aluminium before, so the first one was good practice. I'll make a video on the left hand tank that will find it's way online eventually.
Tank is made out of 1050A aluminium formed around an MDF buck I made based on some dimensions I got from a few people on here. All the the tubes and weld-in fittings are 6066 T6. Everything has been welded with 4043 filler and a cheap 200A AC/DC TIG welder.
Serge
« Reply #385 on: Saturday,July 16, 2016, 01:41:14 PM »
They came out great, Serge!
What amperage welder did you use for your frame? Did you use the same one ?
« Reply #386 on: Saturday,July 16, 2016, 04:52:40 PM »
Sweet!
Offline Serge
    • Sleurs Motorsport
« Reply #387 on: Saturday,July 16, 2016, 06:21:51 PM »
Yes, I used the same welder. I use a footpedal to operate the machine, so not sure what amperage I am actually using.
I also played around with some strengthening ribs in the sides of the tank, as per the originals. I found a good way to do it, but the panels would always warp a bit and I decided not to use them in the end. It does look a little bit less like the original tanks, but they don't need the ribs for strength. I also planned to put baffles inside, but that was a pain to weld, so didn't use those.
Offline StephenH
« Reply #388 on: Sunday,July 17, 2016, 11:49:08 PM »
Went out to play with the big boys today, a Lotus club run with 3 randoms (Boxster, 458, Diablo).
Shows how sportscars have changed in size over the years.
But I kept him in my rear vision mirror with pure Europa goodness......
« Last Edit: Sunday,July 17, 2016, 11:51:10 PM by StephenH »
Stephen
54/1690 1969 S2
« Reply #389 on: Monday,July 18, 2016, 09:02:50 AM »
Nice work, Stephen. Represent  :lotus:
