Author Topic: What does your Europa look like *today* ?  (Read 124242 times)
Offline TheKid#9
Re: What does your Europa look like *today* ?
« Reply #255 on: Sunday,November 30, 2014, 10:39:17 AM »
Nuk- Are those Elan M100 wheels on your Europa too??
« Reply #256 on: Sunday,November 30, 2014, 11:46:30 AM »
Nuk,
I think you can live without a tach, but I think you should figure out your oil pressure and temp gauges as soon as you can! They're pretty important! Let us know how it goes!
Offline Nuk
    • Thai British Car
« Reply #257 on: Monday,December 01, 2014, 12:18:11 AM »
Yes, the wheels are from Elan M100, I think the previous owner modified her to fit 4 wheels disc brake from M100  :)
Nuk,
The temp is because the transmitter doesn't work, but the oil pressure, still do not know, any suggestion what should I check?
I am trying to get some parts from Richard (Bank Europa), but it is not easy to get him answer email, I understand that he is quite busy all the time, so I have to wait for a while or sometimes need to find the parts somewhere else.  :-[
Offline Serge
    • Sleurs Motorsport
« Reply #258 on: Monday,December 01, 2014, 03:38:10 AM »
Nuk,
to contact Richard, you just have to call. He doesn't answer any emails.
Serge
« Reply #259 on: Monday,December 01, 2014, 07:28:01 AM »
Serge is correct. It's probably best to call around his lunch time.
Check the pressure gauge. I think it's mechanical. If it is, a PO must have plugged the port in the block where the line is run to the gauge which implies that there could be a leak in either the line or the gauge and one or both should be replaced or repaired. If it's electrical, it could be that the sender needs to be replaced. It might be that the wire came off!
« Reply #260 on: Monday,December 01, 2014, 09:24:27 AM »
[/quote]
[/quote]
On the twin cam, oil pressure indication is mechanical. I would disconnect the oil pressure line and fitting at both ends and make sure nothing is plugged it up. Have the oil pressure gauge checked out to make sure it is working or install a known working gauge to make sure you have oil pressure.
The oil pressure port is located on the right side near the front below the distributor, see picture.
Offline Nuk
    • Thai British Car
« Reply #261 on: Monday,December 01, 2014, 09:48:35 PM »
Thank you Serge, BDA and Joji (especially for the photo)
I am glad you guys are here, where someone with very limited of mechanical knowledge like me can get these useful information to keep our beloved Europa on the road  :beerchug:
Thanks again, cheers  ;)
« Last Edit: Monday,December 01, 2014, 10:40:44 PM by Nuk »
Offline Chuck Nukem
« Reply #262 on: Saturday,December 13, 2014, 11:33:16 PM »
Letting it sit is torment
Offline Serge
    • Sleurs Motorsport
« Reply #263 on: Saturday,January 24, 2015, 03:55:38 PM »
I've put the chassis on the front wheels, put together my driveshafts, custom polyurethane engine and gearbox mounts and dropped the engine block and gearbox in the chassis to do a dry assembly of the rear suspension, coolant tubes, gearbox linkage etc. I'm also on the verge of putting my steering rack back together.
Slow but steady,
Serge
« Reply #264 on: Saturday,January 24, 2015, 04:25:08 PM »
Things are coming along, Serge!  :beerchug:
I was wondering today where you were with your project. I hadn't seen a recent post from you. Please continue to keep us informed!
Offline Serge
    • Sleurs Motorsport
« Reply #265 on: Sunday,January 25, 2015, 12:59:36 AM »
I'm almost a year behind updating my blog and video series, but life's getting in the way. The little spare time I have, I rather work on the car instead of editing videos, but I'm trying to play catch up.
Serge
« Reply #266 on: Sunday,January 25, 2015, 09:56:24 AM »
Believe me, I understand! I'm more interested in your making progress but I do enjoy your videos!
« Reply #267 on: Monday,January 26, 2015, 08:21:02 AM »
Looking good Serge!
« Reply #268 on: Sunday,February 01, 2015, 07:59:36 PM »
Hey Chuck,
How is the progress? With the body disconnected from the frame, how is the frame, engine, suspension work going? It's not the hot Dallas summer so you should be making good progress!! Have you been in contact with Sports Car World? Are they still in business? I tried calling them from the number on their website but that number didn't work...
Offline blasterdad
« Reply #269 on: Sunday,February 01, 2015, 08:22:47 PM »
Dave @ Sports Car World (972)-620-7285
