Author Topic: What does your Europa look like *today* ?  (Read 124242 times)
Offline exarkun1178
Re: What does your Europa look like *today* ?
« Reply #105 on: Sunday,February 02, 2014, 07:34:30 AM »
I found it.  $1000 dollars is steep i think.  would you mind, what is the benefit? is it a 1000$ worth of better braking?
Offline StephenH
« Reply #106 on: Sunday,February 02, 2014, 06:06:48 PM »
will a proportional valve be required for the braking system to equalize front/rear braking pressure?
andyh
I have a dual master cylinder setup with balance bar adjustment on the dash.
So in theory I should now be able to wind in some more front bias.
Then when I fit the bigger front discs I can wind it rearwards again :)
As to the cost, I doubt you can qualify the $$ against actual braking performance in any meaningful way.
I just wanted more braking power, this was a convenient way in my opinion to achieve that.
Could have engineered something from scratch (have done so in the past) but I want to drive this car, not spend most of my time with it in bits.
« Last Edit: Sunday,February 02, 2014, 06:10:20 PM by StephenH »
Stephen
54/1690 1969 S2
Offline Serge
    • Sleurs Motorsport
« Reply #107 on: Saturday,February 08, 2014, 12:49:22 PM »
Just the chassis, but a sneak peek at what my chassis looks like as of yesterday.
Offline Mecky
    • Lotus Europa Racing
« Reply #108 on: Saturday,February 08, 2014, 02:41:05 PM »
That looks magnificant. Especially if you bare in mind that this is the oldest Lotus Europa Chassis in the world. :beerchug:
« Reply #109 on: Monday,February 10, 2014, 03:57:36 AM »
Oh yeah that's looking good :D.  How's the rest of it coming along
Offline StephenH
« Reply #110 on: Tuesday,February 11, 2014, 01:55:12 AM »
Ooh... shiny things hiding behind the rear wheels and a way to turn the heater off a bit more effectively.
Stephen
54/1690 1969 S2
Offline Serge
    • Sleurs Motorsport
« Reply #111 on: Sunday,February 23, 2014, 01:52:07 PM »
Well, I did some work on the front suspension the last few weekends:
- Poly bush everything
- everything cleaned and painted
- new wheel bearings
- new stub axles
- new nuts & bolts
- longer and bigger wheel studs
- new ball joints
I just need to mount the hubs to the stub axles.
Some iPhone pics below.
« Reply #112 on: Sunday,February 23, 2014, 06:59:18 PM »
Serge,
You have an S1, all that has to come off to fit the frame back and glass it in place.  Good practice though ;-)
« Reply #113 on: Tuesday,March 11, 2014, 01:35:10 PM »
At the coffee shop.
Offline Mecky
« Reply #114 on: Wednesday,March 12, 2014, 02:11:29 AM »
Great contrast to the usual, modern, big, mostly grey and silver cars. Only thing missing is the crowd on the chairs, which admires and talks about this yellow car. :pirate:
« Reply #115 on: Wednesday,March 12, 2014, 07:35:33 AM »
Looking good, Mark. How's it running?
« Reply #116 on: Wednesday,March 12, 2014, 01:07:33 PM »
It's running great, thanks to new diaphragms in both carbs.   :beerchug:
Offline Chuck Nukem
« Reply #117 on: Thursday,March 13, 2014, 09:13:45 PM »
I moved my truck out to the building where the lotus is staying. She got a windshield today and looks like a real car!
Here is a shot of the frame too!
Offline Serge
    • Sleurs Motorsport
« Reply #118 on: Monday,March 24, 2014, 01:02:44 PM »
Since the last photos the ARB has been mounted and I've mounted the hubs back on the front suspension and I've restored the front brake calipers. Some quick phone pictures.
Don't pay attention to the location of the brake hose and bleed valve, I was playing around with their placement to get some extra steering articulation. I think I've solved the problem.
I know I'll have to take it all off again, but at least I'm able to correct any errors while the chassis isn't inside the body.
Serge
Offline Valerio Leone
« Reply #119 on: Tuesday,March 25, 2014, 02:41:01 AM »
Good job Serge!
 :beerchug:
