My shifting throw is VERY short, and very positive, and it is adjustable via the shift rods length. I did make the shift rod from shifter to trans all out of aluminum, took some inertia out that way, may try carbon rod at some point. That being said the Subie trans is a knock off of a VW so there is a lot of mass being moved around compaired to a normal trans, so they don't shift as fast as a centrally mounted trans, or a modern designed frt wheel Honda/ Mits,etc. And they are sensitive to type of fluid, I use Red Line NS, it's made for trans axles (diff and synchros) cheers rp
