September 3, 2024 Forum membership reaches 1,600 !!This Community became 12 years old in April 2024.
Both are based on the Ford 105E block.
Well, time has come and I've removed the engine and transaxle from the TC, and have purchased a '01 Zetec blacktop engine.While I'm at it, the body will come off for a frame inspection. Coolant tubes replaced, and I'm sure other things will pop up.In preparation of conversion I've got some questions. I'm sure I'll be back with more. (hence this thread)
QuoteBoth are based on the Ford 105E block.Time to be an anorak, that's not quite correct. The Zeta engine shares the bellhousing bolt pattern as a 105E block, but the Zeta (or Zetec) was based on the CVH block architecture.
