Author Topic: Removing the front bearing dust cover  (Read 1377 times)
Offline Runningwild
« on: Monday,October 05, 2015, 01:34:48 PM »
I'm starting to rebuild the front suspension on my 68 Europa S2.  How do these dust overs come off?  Can't believe I can't figure it out. The car sat in a collection for 32 years and nothing is rusted.  Any help would be appreciated. Manual gives no clue.  What am I missing?   Thanks. Tom
Offline RoddyMac
Re: Removing the front bearing dust cover
« Reply #1 on: Monday,October 05, 2015, 01:40:44 PM »
Are you referring to the dust cap on the hub?  If so, a pair of special pliers works a treat. Failing that thread a sheet metal screw into the hole and grab the screw with a pair of vice grips and pull the cap off, or you could pry it out with a screw driver.  Most of the time I've replaced the caps following servicing the bearings.
Offline Runningwild
« Reply #2 on: Monday,October 05, 2015, 01:43:20 PM »
Thanks. Seems there was a hole in the dust cover already. Should have been the clue I was looking for. I'll do new covers when I'm done. Thanks a lot.  Tom
« Reply #3 on: Monday,October 05, 2015, 02:15:39 PM »
I just screw a large self tapping screw into the hole in the middle and the screw acts as a hub puller giving even push out all round.
The cover is re-useable,and grease cannot leak out of the hole in the middle due to centrifugal force when the wheel is rotating.
« Reply #4 on: Monday,October 05, 2015, 04:25:01 PM »
I had a 10-32 nut tacked in the dust cover so I could do the self-tapping screw trick - but with a machine screw instead. I'm sure both work as well, but I didn't think of using a self tapping screw.
Offline ezuskin
« Reply #5 on: Tuesday,October 06, 2015, 06:24:30 PM »
Sounds less elegant but I've used hammer and chisel and gently tapped around it to work it loose. You guys are too sophisticated for me
Eddie
Europa TC
1972 2068R
« Reply #6 on: Tuesday,October 06, 2015, 08:17:43 PM »
Maybe we just don't have your gentle touch!  ;D
« Reply #7 on: Tuesday,October 06, 2015, 10:21:04 PM »
I use a small screwdriver myself but after the reasoned & elegant engineering posts I thought I'd better keep quiet about it   :-[
« Reply #8 on: Wednesday,October 07, 2015, 05:52:02 AM »
That's all I ever use myself as well.
Offline Nick in Beds
« Reply #9 on: Thursday,October 08, 2015, 05:54:55 AM »
I am embarrased to say that I butchered mine with pliers .... but they are only a couple of quid from Banks !!
« Reply #10 on: Thursday,October 08, 2015, 06:59:39 AM »
Don't feel bad. They look like they were designed to be as difficult to take off as possible!
Offline Runningwild
« Reply #11 on: Thursday,October 08, 2015, 06:12:25 PM »
Thanks for all the comments. I got the dust cover off by tapping all the way around it with a hammer.
