Author Topic: 2112P Restoration  (Read 25657 times)
Re: 2112P Restoration
« Reply #75 on: Friday,February 03, 2017, 07:56:44 AM »
Any news? I hope the paint is done and turned out well, although with paint shops things can sometimes take a bit longer than you expected...
220 hours work so far on 4688R.
« Reply #76 on: Tuesday,July 04, 2017, 12:01:46 AM »
Post some progress pics. I got painted the end of last year. But in the meantime I took on another project of a complete refurbishment of  flat on the Isle of Wight ( of all places) so progress has only just picked up again in the last couple of months.
And I got it's original number plate registered too!!
« Reply #77 on: Tuesday,July 04, 2017, 01:11:38 AM »
A few more bits fitted and a moving car, lights, fitted the old seat just to be able to drive it  :D
« Reply #78 on: Tuesday,July 04, 2017, 05:23:06 AM »
Very pretty! That black is beautiful!
« Reply #79 on: Tuesday,July 04, 2017, 05:35:45 AM »
Kudos... Well done! She lives again! and glad to see you have abandoned the extra mirrors.
« Last Edit: Tuesday,July 04, 2017, 05:47:30 AM by Lou Drozdowski »
« Reply #80 on: Tuesday,July 04, 2017, 05:37:10 AM »
Very nice! Who made the headers? I like what you did with the firewall, is that aluminum?
« Reply #81 on: Tuesday,July 04, 2017, 05:52:29 AM »
Questions:-
1) As you have gas flowed the head, who did it, and are you changing the jets in the Webers?
2) Where did you get the offset cam dowels? My exhaust needs 10 degrees.
Alex in Norfolk.
Are you sure you have the chain on the sprocket correctly?
« Reply #82 on: Tuesday,July 04, 2017, 07:13:16 AM »
Thanks guys. Yes she lives again :D :D  yep lost the mirror on the wings...
The headers are from Banks, the 47 exhaust set up. It does go very close to the temperature sensor and I wanted to keep the heater so the heater valve had to be relocated slightly. I am pleased with how the  wrapping turned out.
Yep the firewall is ally. but I sandwiched a 10mm thick honeycomb between 2 layers of fibreglass first and then riveted  the plate to that. I wanted something that was fairly rigid and provide some sound deadening without much weight and the alloy plate for fire protection.
On the cam sprockets. I am pretty sure I have the sprockets/chain on properly. I had them on and off enough times when setting it up to make sure I measured correctly the offset required.
« Reply #83 on: Wednesday,July 05, 2017, 02:19:01 AM »
A few more picture.  the fitting of the fire extinguisher and battery location.
And putting the doors together. For riveting the frames in place I used a bit of outer heater valve cable cut to length. worked really well.
The ally frames were cleaned up with 120 grit then 300, 1200, 3000 and then polished. The tricky bit was removing the anodising. they look good BUT having removed the anodising the finish is much more delicate but can always be re-polished.
I found the trickiest bit was how best to fit the frame and the quarter lights. The pics are the first one I did and fitted the quarter light second. This was very tricky to do, it worked but not the easiest method. The next door I fitted everything in one go, the tricky part of this was holding things in place to get the first rivet in. I needed a second pair of hands to hold things in place.
« Reply #84 on: Wednesday,July 05, 2017, 05:23:56 AM »
Nicely done!
« Reply #85 on: Monday,January 29, 2018, 11:21:23 PM »
some updates at last.
Fitting lotus elise seats. With the roll cage fitted space is very limited. I could get a bucket seat in the drivers side but  not the passenger side, so I decided to see how a set of elise seats would fit as they have very little padding. I modified them for 4 point harness seats. The passenger side fitted first and used 3mm ally to make up brackets a single from bracket and 2 side brackets, can just be seen in the pic before final fitting. The seat fits perfectly and just clears the door at the shoulder. Maybe not to everyone's taste, but they can be changed later very easily. Fixed passenger seat not on runners. The drivers side I used the runners and made up slightly different brackets (pics later)
Also the rear window fitted. definitely a 4 handed job, you need someone to hold the glass in place as you feed the rubber round. Fit rubber to the window frame first. Start at one side and work the top and the bottom together. You need the special tool to fit the filler or you can make one (which I did) out of a coat hanger that worked just was well, but you definitely need a tool a screwdriver will not do ( tried and kept on pushing the window through so had to restart)
« Reply #86 on: Tuesday,January 30, 2018, 03:56:19 PM »
Really, Really a sweet ride. Congrats
« Reply #87 on: Thursday,February 01, 2018, 01:34:48 AM »
A few more pics,  The drivers seat fitting up to the rails and the boot box cur out and rework to fit around the 47 type exhaust.
« Reply #88 on: Thursday,February 01, 2018, 02:24:50 AM »
Slightly off topic, but those carpets in your car look very neat, especially the seam around the back of the "transmission tunnel".  Did you make them yourself or buy from a specialist ?
« Reply #89 on: Thursday,February 01, 2018, 06:20:39 AM »
Love the new interior light ;-)
Wrap the muffler as well.
