Author Topic: 47 Bodied Project Starts - Slightly Delayed. Big pile of bits to sort out.  (Read 24566 times)
Re: 47 Bodied Project Starts - Slightly Delayed. Big pile of bits to sort out.
« Reply #30 on: Tuesday,September 29, 2015, 01:39:12 PM »
Do the bolt holes in brackets line up with that neat recess/holes on the door panel ? If so I'd go with internal door release mechanisms. It could conceivably be this part ?
http://lotus-europa.com/manuals/s1parts/b/b3.htm
Offline RoddyMac
« Reply #31 on: Tuesday,September 29, 2015, 01:42:41 PM »
They look like the inner door release bits for the early cars (S1 and early S2).   I have one only as the RH door on my car was stripped before I got the car.  I can snap some pics of it in situ the next time I'm in the garage if needed.
Offline StrawberryCheesecake
« Reply #32 on: Tuesday,September 29, 2015, 02:08:19 PM »
You guys are quick on the draw tonight... I'd just found them in the manual and was about to post the answer. Yes, early door releases. Looks like I have two spares.
I also test-fitted the dash in the car. Is this a standard dash structure? The top seems to be black gelcoat. It's moulded in glass fibre.
Also, I have a spare air box for a renault engine, if anyone needs one.
Offline RoddyMac
« Reply #33 on: Tuesday,September 29, 2015, 02:26:50 PM »
That's a Series 1 style dash (though not a genuine one as they're molded into the bodytub).  I'm envious, I'm planning on building one similar for my car. I know Banks sells them, but they're a bit spendy for my budget.
« Reply #34 on: Tuesday,September 29, 2015, 03:00:03 PM »
Oh right... so it sort of goes with the 47 replica theme. I seem to have picked up a lot of good bits with this project, for a lightweight track-focused build. I think it'll be a rattly PITA on the road, with the rose jointed wishbones, plastic windows, etc.
Offline RoddyMac
« Reply #35 on: Tuesday,September 29, 2015, 03:15:21 PM »
I'll have the same issues other than the light weight part.  The damper and the front suspension are the only bits with rubber bushings in them.  But, I'm sure it will be a bit more comfortable than a Seven.
« Reply #36 on: Tuesday,September 29, 2015, 03:25:08 PM »
Is this a custom gear linkage setup? Is it specific to certain gearboxes?
There's a rear frame of some sort, that fits to the rear of the chassis. I've probably got this the wrong way round, but I just offered it up to see if the spacing was the same
Looks like the stuff above is the Spyder NG3 installation and linkage kit.
http://www.spydercars.co.uk/lotus-europa-fuego-5-speed-transaxle-conversion-kit/
« Last Edit: Tuesday,September 29, 2015, 03:36:08 PM by StrawberryCheesecake »
« Reply #37 on: Tuesday,September 29, 2015, 07:33:11 PM »
That's a nice feature of the Spyder frame. I'd say it might be time to go NG3 shopping! :)
« Reply #38 on: Tuesday,September 29, 2015, 09:58:44 PM »
It'll be a bit less draughty anyway... I hope :)
« Last Edit: Tuesday,September 29, 2015, 10:01:56 PM by StrawberryCheesecake »
« Reply #39 on: Tuesday,September 29, 2015, 10:03:03 PM »
Already hunting. Not many Fuegos or early Espaces being broken these days, or even around at all.
« Reply #40 on: Wednesday,September 30, 2015, 08:28:11 AM »
Richard at Banks surely has them and I would think that there should be some on the mainland. Or have they all be snapped up by hot rodders who are building mid-engined road cars? I think I read that the last ones were manufactured in South Africa in the 1990s, but that is a long way to go!
Over here in the states, there is a network of salvage yards that you can search for parts at all the participating yards. I'll bet there's something similar in the UK.
« Reply #42 on: Wednesday,September 30, 2015, 07:11:10 PM »
The air filter housing pictured above is from twin cam.
« Reply #43 on: Thursday,October 01, 2015, 12:51:48 AM »
 :happy-bday:
Thanks - I've also heard they're all pretty similar - I won't be using it, so if anyone wants one please let me know.
