Author Topic: Seat mounts  (Read 773 times)
Offline Gmg31
Seat mounts
« on: Saturday,August 22, 2015, 02:04:40 AM »
are seats really just bolted straight through the fibre glass floor? It's all looks a bit flimsy to me!
Re: Seat mounts
« Reply #1 on: Saturday,August 22, 2015, 04:44:30 AM »
The seat mounting pair of sliding rails are bolted to two threaded metal inserts in the fibreglass floor.
Offline Gmg31
Re: Seat mounts
« Reply #2 on: Sunday,August 23, 2015, 08:50:05 AM »
Oh dear, mine weren't. Mine has been a re shelled project which was never finished. I think I'll make some sort of reinforced steel floor brackets. Thanks for the advice.
Re: Seat mounts
« Reply #3 on: Sunday,August 23, 2015, 08:54:06 AM »
It might be worth looking at some aftermarket seat mounts as they use in kit cars, that's probably the easiest way to come up with an adjustable seat. The Lotus ones are just two strips of steel that the seat slides along and they're bolted into the floor.  Nothing fancy, they just spread the load a bit.
Offline Gmg31
Re: Seat mounts
« Reply #4 on: Sunday,August 23, 2015, 10:35:16 AM »
Great idea thanks
Re: Seat mounts
« Reply #5 on: Sunday,August 23, 2015, 11:01:02 AM »
I always was concerned that my rear end was sitting 4"-5" above the ground with a couple of layers of fiberglass for protection. Toyed with the idea of placing a thin sheet of aluminum or steel on the outside under the seat area to further spread the load and act as a barrier to projectiles.
Offline Gmg31
Re: Seat mounts
« Reply #6 on: Sunday,August 23, 2015, 11:33:42 AM »
I was thinking much the same, a nice piece of Aluminium Chequer plate would do the job and protect the underside
