Author Topic: Rear Hub Bearing Spacers  (Read 1405 times)
« on: Wednesday,September 05, 2012, 05:24:56 PM »
I'm going through my spare parts and ran across a set of titanium bearing spacers. The repair manual says that the T/C Special uses a spacer that is 2 inches, while the T/C spacer is 2.125 inches. However the bearing numbers are the same for the T/C and the T/C Special. So I'm assuming that the carrier for the T/C versus  the T/C Special are different.  :confused:
Has anyone looked at the difference between the two? The parts book list part number 074-D-0913Z with a prefix of "B" for the T/C and "E" for the Special.
Maybe the distance between the bearings was closer (.125)  on the Special versus the T/C.
Re: Rear Hub Bearing Spacers
« Reply #1 on: Wednesday,September 05, 2012, 10:24:08 PM »
I think it's down to the bearings Joe. The TC uses one 6006 (30mm x 55mm x 13mm) and one 6206 (30mm x 62mm x16mm), whereas the Special uses two of the 6206's, the same for inner & outer. I think that mod came in around the time of the wider brake drums.
So if you had the same hub carrier & accommodated the extra 3mm on the TCS bearing by machining into the casting then there would be 3mm, 0.125" less gap to fill between bearings ?
ps - for some reason the part numbers are different in my book.
Bearings - TC inner, A074D 6001Z, TCS inner X036D 6017Z, TC & TCS Outer X036D 6017Z
Bearing Spacers  - TC spacer X046D 0148Z,  TCS spacer A074D 0215Z.
Looks like there's something screwy there, my parts book is an olde worlde dead tree version dated Sept. 1972 ?
Offline Chuck Nukem
« Reply #2 on: Friday,December 27, 2013, 06:40:38 PM »
How much did that titanium spacer set you back Joe? I am shopping for my spacers right now. I am half thinking about making a set for my car. Have you had any luck with a hardened spacer over the original?
