Author Topic: Radiator Cap  (Read 750 times)
Offline Lotusjps
Radiator Cap
« on: Monday,August 03, 2015, 01:58:28 PM »
Does anyone know where to find a 10psi radiator cap for a closed (using an over flow tank) system?  I've found several for the original open system, but of course it won't suck the coolant back from the overflow.
I see that Dave Bean offers one that's 15-18psi, though I'm not sure about upping the pressure that much.
Re: Radiator Cap
« Reply #1 on: Monday,August 03, 2015, 02:09:29 PM »
A quick search on Summit Racing shows 7  - Seven lbs caps and 17 -  Thirteen lbs caps, but no Ten lbs caps  :confused:
I did find one on Amazon
http://www.amazon.com/Stant-10237-Radiator-Cap-PSI/dp/B000C846M8
« Last Edit: Monday,August 03, 2015, 02:11:33 PM by LotusJoe »
Offline Lotusjps
Re: Radiator Cap
« Reply #2 on: Monday,August 03, 2015, 02:41:11 PM »
Wow that was fast.  I'm checking it out, but how can you tell that it will fit the Europa?  I also checked it out on the Stant web site and see it fits a 1970 MBG, but it does give dimensions.
