Author Topic: ELSE Europa restoration 2015 -2018  (Read 75881 times)
Offline Gmg31
Re: Europa restoration 2015
« Reply #30 on: Monday,August 03, 2015, 01:20:59 PM »
Full restoration Superb finish, £125 for the carb and £40 for the manifold
« Last Edit: Monday,August 03, 2015, 02:36:45 PM by Gmg31 »
« Reply #31 on: Monday,August 03, 2015, 04:19:28 PM »
That's really pretty!  :beerchug:
Offline Gmg31
« Reply #32 on: Tuesday,August 04, 2015, 08:49:24 AM »
This guy has been very good, quick service, loads of advice and affordable.
« Reply #33 on: Thursday,August 06, 2015, 07:58:25 AM »
Hmm,
Think I'll give the guy a ring. lovely job.
Offline Gmg31
« Reply #34 on: Sunday,August 23, 2015, 10:38:45 AM »
I needed some early results to keep my enthusiasm up  so I've started doing some prep work on the interior. Fully restored and cleaned seats
« Reply #35 on: Sunday,August 23, 2015, 02:16:21 PM »
They look great! Upholstery is just one of the things I would never consider attempting...
« Reply #36 on: Sunday,August 23, 2015, 10:20:57 PM »
Wow, they look good.
Were they good enough just to clean up or is that a home re-trim ?  If so, you have a real talent there.
Offline Gmg31
« Reply #37 on: Monday,August 24, 2015, 12:47:37 PM »
A mix of both, the rear of one seat was rusted through and needed re fabricating.  4 of the pads needed new sponge and rear boards but all of the vinyl was in good condition. The hardest part was cleaning the basket weave it is so difficult to clean out all the little crevices.
Offline Gmg31
« Reply #38 on: Monday,August 24, 2015, 12:55:48 PM »
Such a frustrating day today. This car has stood for 35 years and every bolt is seized or corroded.  I had to take an angle grinder to the U bolts and brackets today to free off the steering rack.
Offline Gmg31
« Reply #39 on: Monday,August 24, 2015, 12:59:15 PM »
And then one of the wheel nuts sheered off
« Reply #40 on: Monday,August 24, 2015, 01:06:46 PM »
ouch, that looks nasty, but sometimes you just aren't going to get things done without brute force.   If the car is as rust-bound as that then I think I'd just invest in a few slitting discs for the grinder and give up trying to salvage the nuts and bolts.
If there's no petrol around then it might be worth trying a propane torch to see if you can shake them, but they take so much bashing to get them off it's questionable if you'd want to use them in critical areas anyway.
edit to add - and the wheel nut looks even worse !  I think this is what's called "in at the deep end" or "baptism of fire" on the grand scale of Lotus restoration. On the plus side - that must be so dispiriting that things can only get better !
« Last Edit: Monday,August 24, 2015, 01:11:01 PM by EuropaTC »
« Reply #41 on: Monday,August 24, 2015, 05:05:44 PM »
Very common to over torque the Europa/Spitfire wheel nuts, damaging the threads.
« Reply #42 on: Thursday,August 27, 2015, 05:07:07 AM »
propane torch by itself cannot give enough focused heat. I would use one of these oxygen/gas welding torches. they are great pieces of kit. you can focus the heat on the parts you want and there is a much better chance of getting the bit apart rather than hacking it with a cutting disc.
http://www.weldingshop.co.uk/diy-hobbyist-c-139/oxyturbo-110-gas-welding-kit-p-377.html?zenid=d4d51b2a04ff5e52245be96bc2486bfe
great hobby gas welding kit, not particularly cheap but if you have to buy new brackets for the steering rack and other brackets you will save the money. I bought one earlier this year and wish I'd done it sooner!
Offline Gmg31
« Reply #43 on: Friday,August 28, 2015, 01:48:08 PM »
Well it turns out my car has 1 extra bolt on top of the tunnel bolted directly into the backbone.  Even Richard didn't know about this bolt!! So eventually the shell is off and going to paint next week. The body shop is happy to take 2 months to do the work which gives me time to restore the chassis brakes and suspension.
  I have been a bit disappointed with the quality of the "out of sight" fibre glass even on this replacement shell. So I purchased a huge bucket of gel coat and I've been painting it on all the internal unfinished surfaces before going to paint.
« Last Edit: Friday,August 28, 2015, 01:50:51 PM by Gmg31 »
« Reply #44 on: Friday,August 28, 2015, 03:05:57 PM »
Glad you finally got it separated!
I wouldn't complain too much about the fiber glass quality. It seems to me that it was better in the Elan and S2 than the TC, but people who have more direct experience with them may disagree, but the glass on my TC that didn't show was of varying quality. Part of the floor in front of the front trunk was thin, it wasn't well finished in the engine compartment, and, of course, the boot, bonnet, and doors don't fit all that well.
Keep in mind that you're dealing with a Lotus.  :)
