Author Topic: ELSE Europa restoration 2015 -2018  (Read 75827 times)
Re: ELSE Europa restoration 2015 -2018
« Reply #405 on: Monday,June 18, 2018, 09:09:39 AM »
1200 miles is good, that's more than I normally do although I'll admit I only ever use my old cars when the sun's shining...   which is sometimes "challenging" in the UK  ;)
I wonder if your gearbox problems are shift-related ?  With my shift mechanism there's not very much you can do apart from the middle joint dimensions but I wonder if there's any tweaking you can do with the arm lengths on yours ?  It just sounds odd if there's no untoward grumbling from the box and it shifts down ok, it makes me wonder if the linkage isn't quite spot on.
But even so, I'd say you're doing quite well with such a small "snag sheet".
« Reply #406 on: Tuesday,June 19, 2018, 03:23:24 AM »
Good going on getting some miles on it. on going to a 5 speed to fix the leaks I would not be sure that would fix the leaks. you will be swapping one leak for another. I am having problems with leaks on my 5 speed. on fitting carpets on the sill carpet I glued in place and tried to the edge of the door seal and that worked well. On the floor carpet I intend to use some 2 inch velcro strips to hold the carpet in place and see if that works.
On shifting what oil are you using the right oil. I am using a GL4 good quality mineral and that helps and the change up 2nd to 3rd I find the trickiest too. I would agree linkage is potentially the main culprit.
« Reply #407 on: Tuesday,June 19, 2018, 03:39:29 AM »
On the carpet issue, my Type 54 had carpet press studs in the floor.
I recall there were probably two on each side of the backbone, but the actual number may be wrong.
Anyone else have these?
« Reply #408 on: Tuesday,June 19, 2018, 03:54:01 AM »
R & D has a carpet set fasteners...$14.95
Cheers!
« Reply #409 on: Tuesday,June 19, 2018, 08:31:57 AM »
Any of the British parts suppliers will have them.  Probably your local auto/marine upholstery shop as well.
Offline Gmg31
« Reply #410 on: Tuesday,July 17, 2018, 03:37:51 PM »
Took my car to my trusted autotrimmer last week. And he worked Miracles.  I had several issues that I just didn’t have the skills to correct. When I fitted the roof lining there was no way of joining it to the top of the screen in a neat way. Similarly the A pillar and the edge of the lining above the doors were just not good enough.  I went for the best carpet on the market and my trimmer has edged every piece with leather.  I also bought a cheap drinks holder from eBay and he trimmed it all to match and fitted it to the bulkhead. Very very happy with result.
Offline Gmg31
« Reply #411 on: Tuesday,July 17, 2018, 03:40:05 PM »
Some more
« Reply #412 on: Tuesday,July 17, 2018, 05:03:11 PM »
The carpet, headliner look great.
« Reply #413 on: Tuesday,July 17, 2018, 08:16:34 PM »
That looks spectacular! That is very nicely done! She really is a beauty inside and out! Congratulations!
 :lotus:
« Reply #414 on: Wednesday,July 18, 2018, 01:36:10 PM »
Your head liner is beautiful. I am now ashamed of mine and will redo before reinstalling my windshield.
« Reply #415 on: Thursday,July 19, 2018, 09:01:21 AM »
Looking great. Very tidy work. That will spruce up the office nicely.
« Reply #416 on: Monday,July 23, 2018, 03:42:26 AM »
Impressive work! I was going to leave my headliner stock but you have given me some ideas.
Offline Yellowbelly
« Reply #417 on: Monday,July 23, 2018, 06:39:57 AM »
Having followed your threads over the last few months it was good to see the car in the flesh at Silverstone and i can confirm that it looks even better than the pictures show.
Offline Gmg31
« Reply #418 on: Wednesday,July 25, 2018, 02:07:02 PM »
Good to meet you Paul. I look forward to seeing your project, especially your plan for AC we were sweltering on the way home on Sunday!!
Offline Gmg31
« Reply #419 on: Friday,March 01, 2019, 02:43:40 PM »
A fantastic first year 3600 miles and surprisingly few issues.  As the season drew to a close I was only able to get 2nd and 4th gears and gear box oil leaks were deteriorating.  So after a brief rest I got back into the workshop this week.  Gearbox out, new seals and a fresh coat of paint.  New gear linkage and lever from Banks.
